InterFoam - setFields for a non-rectangular 3D domain
Like Tree3Likes
Old   August 3, 2015, 13:40
Saideep
Saideep is on a distinguished road
Hi Guys;
I know this is quite an old post but just got stuck with a problem recently.
So, i use interFOAM in OpenFOAM 2.3.1 and i would like to set values for the phases in specific regions of the domain.
Well I tried to initialize the values with our friendly setFields utility but it accepts only one set of values. The second set of value is omitted.
So, is it possible to set the values at specific discontinuous parts of the domain with the setFields utility that i am not aware of?
Else can i use the funkySetFields utility but it says the development is transferred further on to the utility named swakySetFieldDict.
Will funky utility work on OF 2.3.x else i have no option other than to use swakysetfieldsdict?
Thanks;
Saideep
Saideep is offline   Reply With Quote
Old   July 24, 2020, 19:58
AmiN
AmiN.D is on a distinguished road
This is an old thread but I want give it a try and ask a question about setField, I'm simulating a U shaped barometer in 3D with snappyhex and interFoam and kinda confused about setting the initial condition for Alpha.
How can I set my SetField to get a results like the attached picture?
File Type: png Screen Shot 2020-07-24 at 11.58.43 PM.png (105.3 KB, 9 views)
AmiN.D is offline   Reply With Quote
Old   July 24, 2020, 22:55
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
There are two scenarios:
1. Create a cellZone corresponding to your initial liquid volume with snappyHexMesh and use setFields with zoneToCell option
You might want to check the tutorial to crate a cellZone with snappyHexMesh: incompressible/pimpleFoam/RAS/propeller
2. Generate mesh without cellZone and use setFields with boxToCell option(You can also use setAlphaField utility)
Hope this helps,
Fumiya
AmiN.D likes this.
[Personal]
fumiya is offline   Reply With Quote
Old   July 25, 2020, 06:17
AmiN
Originally Posted by fumiya View Post
Hope this helps,
Fumiya
Thanks for the quick answer.
I think I would go for the second scenario [first option may take time to get to know everything there]
but I thought boxToCell is just for Hexa mesh and not for non-structural mesh. I couldn't comprehend giving a box coordinate in a pipe which can cover the red are [in picture above] at time 0 . But thank you for making me to read the User Guide again and correct my wrong assumptions.
Old   July 25, 2020, 22:16
fumiya's Avatar
Fumiya Nozaki
In the first scenario, mesh lines generally do not align to your initial liquid volume(particularly in the case of unstructured meshes as you wrote), so obtained initial alpha distribution might be in a zig-zag manner.
If the shape of your initial liquid volume is complex, you might want to use insideCells utility to create cellSet from the enclosed volume of the input stl geometry.
[keywords]
*insideCells: Create a cellSet for cells with their centres ’inside’ the defined surface. Requires surface to be closed and singly connected
Hope this helps,
Fumiya
AmiN.D likes this.
[Personal]
interfoam, openfoam 1.5, setfields
Domain format problem on airfoil flow simulation andrenonaka CFX 14 December 7, 2015 01:42
setFields doesn't function for a tetrahedral mesh - interFoam tommie OpenFOAM Pre-Processing 5 April 15, 2010 04:32
CFX Solver Memory Error mike CFX 1 March 19, 2008 08:22
[blockMesh] BlockMesh for a rectangular domain with curved bottom surface segersson OpenFOAM Meshing & Mesh Conversion 0 April 17, 2006 15:11
Import a rectangular domain into CFX 5.7 from ICEM SKLam CFX 9 March 8, 2006 01:47
