June 3, 2010, 07:36 |
DTMB and wigley
Diego Villa
Rep Power: 16 |
Hi
I'm a new openFOAM user, I'm trying to computate the free surface ship problem. Until now I'm trying 2 different approach: 1) I try to run the simulation of the wigley in a structured mesh with the OF1.6(case made by Eric Paterson (thanks for the link!!!!)) but after 1 second of physical time the water level go down. (I use the interFoam solver) 2) I try the DTMB case using the snappyHexMesh but only after few iteration the pressure field diverge. Some one has solved a similar problem? Could gave me the right Boundary condition and the case condition? Thanks a lot. |
June 16, 2010, 11:03 |
mikael
Rep Power: 16 |
Hi Diego
I'm a new OF user too and I'm working on a similar project. I suggest you to have a look at this different cases: 1- http://www.tfd.chalmers.se/~hani/kurser/OS_CFD_2008/ where you could find an archive named my6DOFFoam which is an example of floating object. 2- http://openfoam-extend.svn.sourcefor...ydrodynamicIG/ which contains one sovler called shipFoam, BC's library (waveBC) and tutorials. I've managed to compile them with more or less difficulty but I think it's a good startpoint. Good luck! |
free surface, ship |
