Floating point exceptioninterFoam
Old   May 27, 2010, 09:50
Question Floating point exceptioninterFoam
Ramnik Singh
Ramnik is on a distinguished road
Hey,
I am running a emptying process using interfoam. i get this error after sometime n i cannot figure out y.
rsingh@knicklenker:~/openfoam/SurgeTank/SymTANKMESHMOD> #0 Foam::error:rintStack(Foam::Ostream&) in "/mnt/opt.net/src/OpenFOAM/OpenFOAM-1.6/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/mnt/opt.net/src/OpenFOAM/OpenFOAM-1.6/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 ?? in "/lib64/libc.so.6"
#3 void Foam::MULES::limiter<Foam::geometricOneField, Foam::zeroField, Foam::zeroField>(Foam::Field<double>&, Foam::geometricOneField const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::zeroField const&, Foam::zeroField const&, double, double, int) in "/mnt/opt.net/src/OpenFOAM/OpenFOAM-1.6/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libfiniteVolume.so"
#4 void Foam::MULES::explicitSolve<Foam::geometricOneField , Foam::zeroField, Foam::zeroField>(Foam::geometricOneField const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&, Foam::zeroField const&, Foam::zeroField const&, double, double) in "/mnt/opt.net/src/OpenFOAM/OpenFOAM-1.6/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libfiniteVolume.so"
#5 Foam::MULES::explicitSolve(Foam::GeometricField<do uble, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&, double, double) in "/mnt/opt.net/src/OpenFOAM/OpenFOAM-1.6/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libfiniteVolume.so"
#6 main in "/mnt/opt.net/src/OpenFOAM/OpenFOAM-1.6/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/interFoam"
#7 __libc_start_main in "/lib64/libc.so.6"
#8 _start at /usr/src/packages/BUILD/glibc-2.10.1/csu/../sysdeps/x86_64/elf/start.S:116
^C
[1]+ Floating point exceptioninterFoam > log
need help
Thanks in advance.
Ramnik
Ramnik is offline   Reply With Quote
Old   May 27, 2010, 10:07
Vishal Jambhekar
vishal is on a distinguished road
PPl as far as i think this error is due to overshoot of delta t for critical time step. as the erroe explicitly comes form explicit solver. Dose anyone have any other datails for the erroer........!!!
pls let us know....
Cheers,
Vishal Jambhekar...
"Simulate the way ahead......!!!"
vishal is offline   Reply With Quote
Old   June 3, 2010, 21:50
Kishore, A.
Ak_cfd is on a distinguished road
Are you running Interfoam for your problem using a fixed deltaT or run-time modifyable deltaT ? Based on the Courant number calculated by the solver, the deltaT will keep chamging in order to satisfy your Max Courant number limit that you have prescribed in the controlDict file.
Of course, you need to tell us a little bit more about the problem, and when this error occurs.
Cheers,
Aravind
Ak_cfd is offline   Reply With Quote
Old   October 24, 2010, 16:09
abdikerim kurbanaliev
kerim is on a distinguished road
Dear All,
I have similar problem with interFoam. Could someone help me to fix it? I'm using runTimeModifiable yes option for time step, but a Courant number is increasing fast.
Thanks,
Kerim
kerim is offline   Reply With Quote
Old   October 25, 2010, 05:51
Vishal Jambhekar
Hi Kerim,
In that case. MAy be it comes because your problem involves sudden rise in pressure / velocity. check for skewness of elements for your mesh. (As i dont know which kind of mesh you are using). In case you expect suddden changes in values. try vanLeer schemes.
I guess that could help you...!!!
One more important thing is : i guess you cant just specify runTImeModifiable. along with that one should also apecify adjustTimestep maxCo and maxDeltaT : please check userguide U-61.
Cheers,
Vishal Jambhekar...
floating point, interfoam
floating point exception? syd STAR-CCM+ 3 April 20, 2010 19:55
Floating point exception error with small DeltaT rassilon OpenFOAM Running, Solving & CFD 19 September 2, 2009 08:39
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 03:27
Floating point error Nabil FLUENT 2 January 19, 2007 06:30
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
