Surge tank emptying using interFoam- Stops when surface reaches outlet |
May 26, 2010, 10:46 |
Ramnik Singh
Rep Power: 17 |
I am a lil new to openFOAM. I am trying ti simulate the emptying process of a surge tank. Its like a tank with a atmospheric opening at top ant outlet at bottom. Its initially filled with water. Now I am using RANS kE model for simulation. It runs fien till the surface touches the outlet then it gives an error. final.png MULES: Solving for alpha1 Liquid phase volume fraction = 0.670639 Min(alpha1) = 0 Max(alpha1) = 1.00568 MULES: Solving for alpha1 Liquid phase volume fraction = 0.670638 Min(alpha1) = 0 Max(alpha1) = 1.01137 MULES: Solving for alpha1 Liquid phase volume fraction = 0.670638 Min(alpha1) = 0 Max(alpha1) = 1.01706 MULES: Solving for alpha1 Liquid phase volume fraction = 0.670638 Min(alpha1) = 0 Max(alpha1) = 1.02275 DICPCG: Solving for p, Initial residual = 0.0992787, Final residual = 0.00352065, No Iterations 3 DICPCG: Solving for p, Initial residual = 0.0016073, Final residual = 7.41546e-05, No Iterations 21 DICPCG: Solving for p, Initial residual = 0.000173425, Final residual = 9.82588e-08, No Iterations 109 time step continuity errors : sum local = 0.282273, global = 0.00788512, cumulative = 0.00788587 DILUPBiCG: Solving for epsilon, Initial residual = 0.110028, Final residual = 2.53095e-10, No Iterations 6 bounding epsilon, min: -3.72537e+06 max: 1.27902e+20 average: 5.69326e+17 DILUPBiCG: Solving for k, Initial residual = 0.220076, Final residual = 3.50192e-10, No Iterations 3 bounding k, min: -2.36398e-06 max: 8.31733e+10 average: 1.65517e+08 ExecutionTime = 29.2 s ClockTime = 104 s Courant Number mean: 13.1522 max: 23472.1 deltaT = 9.41571e-11 --> FOAM Warning : From function Time:perator++() in file db/Time/Time.C at line 682 Increased the timePrecision from 8 to 9 to distinguish between timeNames at time 5.85179 Time = 5.85178531 --> FOAM Warning : From function Time:perator++() in file db/Time/Time.C at line 682 Increased the timePrecision from 9 to 10 to distinguish between timeNames at time 5.85179 MULES: Solving for alpha1 I have specified my controlDict as application interFoam; startFrom startTime; startTime 1; stopAt endTime; endTime 10; deltaT 0.01; writeControl adjustableRunTime; writeInterval 0.05; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression uncompressed; timeFormat general; timePrecision 6; runTimeModifiable yes; adjustTimeStep on; maxCo 0.5; maxDeltaT 1; I need help.. Thanks in advance.. Ramnik |
March 14, 2012, 07:26 |
I need your help.
Seon Hye
Rep Power: 14 |
Hi.
I'm new to OpenFOAM and I met the same problem as you. Did you solve it? I use pimpleDyMFoam. Strangely, depending to the rotation speed, somtimes this error disappears in the same analysis model. |
free surface, interfoam, outlet boundary, surge tank, vof |
UDF Defining VOF Free Surface at Outlet | Alex | Fluent UDF and Scheme Programming | 13 | August 8, 2012 16:50 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
recirc tank, inlet outlet conditions | david | CFX | 1 | May 22, 2007 03:23 |
VOF Outlet boundary condition in cfd - ace | JM | Main CFD Forum | 0 | December 15, 2006 08:07 |
Inlet & Outlet Boundaries causing low surface temp | Ted Crilly | Siemens | 2 | November 19, 2004 08:58 |
