Plunging Airfoil Problem
Old   May 17, 2010, 23:36
Default Plunging Airfoil Problem
jmo
jmo is on a distinguished road
Hi everyone,
I am knew to OpenFOAM (and CFD and general) and am having an issue with moving meshes. My goal is to simulate a moving airfoil in 2D, where the airfoil movelement can be specified arbitrarily as a function of time. I was wondering what the best way to do this is?
I have run some test cases. First, I validated the struhaul number for an unsteady cylinder in low Re flow, and secondly I simulated a static airfoil started impulsivley. Neither gave me any issues.
I then decided to simplify the problem by setting Uinf for for the cyclinder case to 0 and linearly translating the entire mesh using the function "solidBodyMotionFvMesh" and selecting " the Sea Keeping Analysis model (SKA) which allows for 6DOF motion. The mesh movement works, as I can see it happening in paraView, however, the results are vastly different from the stationary grid case. The two results should be identical. I end up getting these pressure and velocity waves in the solution, which I think are numerical artifacts. Many times the solution will diverge because of these.
Does anyone have a clue what could be going on here or another way to approach the problem? Any help would be great...
Thanks
John
jmo is offline   Reply With Quote
Problem running simpleFoam on a multi element airfoil vinz OpenFOAM Running, Solving & CFD 18 April 11, 2013 12:26
Problem Meshing Airfoil erodv OpenFOAM 12 January 11, 2012 18:46
plunging airfoil Quarkz Main CFD Forum 3 July 12, 2011 06:55
[FloWorks] Request advice for an airfoil calculation problem Bogey Jammer Main CFD Forum 0 September 29, 2009 18:06
Periodic flow boundary condition problem sudha FLUENT 3 April 28, 2004 09:40
