May 7, 2010, 10:22 |
Mixing layer with OpenFoam
Hi everybody!
I'm a new user in OpenFoam. I have done some tests and simulations and now I have a problem. I have to solve a mixing layer with the solver sonicFoam between supersonicFlow and subsonic flow, with the k-Epsilon model of turbulence. I'm having some problems with the boundary conditions, like the outlet and in the zone between the two flows. What boundary conditions do you recommend to me? And what initial values for k and epsilon? Thanks! |
April 18, 2011, 00:52 |
anything?
Seyyed Ali H.M.
Rep Power: 17 |
Hi, did you find good boundary conditions for your case.
I`m trying to do a subsonic high Ma shear layer, I tried different BCs, but my results doesn't look good, they're different with the stuff published before. Any Idea?
SAHM |
k-epsilon, openfoam, turbulence |
"Shear layer" vs. "mixing layer"- Difference | mazadeh | FLUENT | 2 | April 18, 2008 15:46 |
errors | Fahad | Main CFD Forum | 0 | March 23, 2004 14:20 |
Validation of shear mixing layer using kwsst | Samuell | FLUENT | 0 | September 9, 2003 23:46 |
Validation of shear mixing layer using kwsst | Samuell | FLUENT | 0 | September 9, 2003 23:27 |
LES unsteady : Turbulent Mixing Layer | Flav | FLUENT | 5 | December 13, 1999 04:11 |
