Running PimpleDyMFoam in parallel
Old   May 6, 2010, 13:03
Default Running PimpleDyMFoam in parallel
Paul Bomke
paul b is on a distinguished road
Hey Guys,
I got stuck trying to run pimpleDyMFoam in parallel. The decomposition ran through without throwing any error messages but if I try and do:
mpirun -n 4 pimpleDyMFoam -parallel
I get:
Create time
Create mesh for time = 0
Selecting dynamicFvMesh dynamicMotionSolverFvMesh
Selecting motion solver: velocityLaplacian
[0]
[0]
[0] --> FOAM FATAL IO ERROR:
[0] size 898 is not equal to the given value of 518
[0]
[0] file: /home/bionik/CFD/williamsWing5/processor0/0/pointMotionU::boundaryField::wing from line 55 to line 71.
[0]
[0]     From function Field<Type>::Field(const word& keyword, const dictionary&, const label)
[0]     in file /home/bionik/OpenFOAM/OpenFOAM-1.6.x/src/OpenFOAM/lnInclude/Field.C at line 237.
[0]
FOAM parallel run exiting
[0]
[2]
[2]
[2] --> FOAM FATAL IO ERROR:
[2] size 898 is not equal to the given value of 470
[2]
[2] file: /home/bionik/CFD/williamsWing5/processor2/0/pointMotionU::boundaryField::wing from line 55 to line 71.
[2]
[2]     From function Field<Type>::Field(const word& keyword, const dictionary&, const label)
[2]     in file /home/bionik/OpenFOAM/OpenFOAM-1.6.x/src/OpenFOAM/lnInclude/Field.C at line 237.
[2]
[2]
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 1.
I know there has been a similar posts somewhere in the forum but it doesn't work for me.
So it seems to me that something is wrong with how the moving patch is distributed over the processors. If I take a look at the pointMotionU-files in the processor folders they show a big mess in the region where the boundary condition for the moved mesh is stated.
The case can be downloaded from here:
http://exchange.hs-bremen.de/exchange?g=sdknrn
I would really appreciate if someone could help me to get this running...
Best regards
Paul
paul b is offline   Reply With Quote
Old   May 10, 2010, 05:30
Paul Bomke
Hey all,
please, is there nobody out there who encountered the same problems?
In this thread: http://www.cfd-online.com/Forums/openfoam-bugs/64751-parallel-moving-mesh-bug-multi-patch-case.html
the advice of parallel preprocessing is given. What does this mean? Do I have to do the preprocessing for each processor?
I would be really glad if someone could comment on this for I'm really stuck here at the moment.
Thanks a lot,
Paul
ps. forgot to mention: I'm using OF 1.6.x
Old   June 13, 2010, 11:59
John Wang
cwang5 is on a distinguished road
Hi Paul,
Have you managed to resolve the problem? I have encountered similar problem using pimpleDyMFoam and could use some guidance. Thanks.
John
cwang5 is offline   Reply With Quote
Old   June 14, 2010, 04:33
Paul Bomke
Hey John,
sorry to disappoint you but I didn't solve the problem. I'm using 1.5-dev now and it works quite well...
If you come up with a solution please let me know
paul
Old   April 19, 2011, 10:41
flowris is on a distinguished road
Hi Paul,
I am suffering from the same problem as you when running a moving mesh in parallel:
[0]
[0]
[0] size 406 is not equal to the given value of 116
[0]
[0] file: /home/jmatthei/OpenFOAM/jmatthei-1.6-ext/run/testPatchDeform/pitching10k/processor0/0/pointMotionU::boundaryField::airfoil from line 48 to line 465.
[0]
[0]     in file /home/jmatthei/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude/Field.C at line 237.
I use 1.6-ext, motionSolverLibs ("libfvMotionSolver.so") and angularOscillatingDisplacement. Did you resolve your problem already?
flowris is offline   Reply With Quote
Old   April 19, 2011, 18:37
Paul Bomke
Forget about the velocityLaplacian and use Hrvoje Jasaks tetDecomposition motion solver as it seems to be more robust and can handle larger deformation.
Hope it works!
Paul
Old   April 19, 2011, 21:12
Mathieu Olivier
mathieu is on a distinguished road
Dear Flowris,
There is a point field p0 that is probably written in processor*/pointMotionU (or pointDisplacement) on the angularOscillatingVelocity (or angularOscillatingDisplacement) patch when you decompose the field.
p0 nonuniform List<vector>
80
(-0.3535 -0.3535 0)
(-0.3535 -0.3535 0.25)
(-0.293859 -0.404472 0.25)
... etc ...
Just remove that field in all processor*/pointMotionU (or processor*/pointDisplacement) and see if it works.
Mathieu
mathieu is offline   Reply With Quote
Old   April 20, 2011, 05:19
Mathieu,
I deleted the p0 nonuniform List, and the cases moves in parallel. The mesh is distorted where the processor boundaries meet the moving wall, see
http://www.cfd-online.com/Forums/ope...1-6-ext-2.html
Old   April 20, 2011, 06:21
Paul,
Thanks for the tip. I tried to use pseudoSolidFaceDecomposition. angularOscillatingDisplacement cannot be used with it, since it is written for the fvMotionSolver. Do I have to rewrite it, e.g. here:
/src/dynamicMesh/meshMotion/tetDecompositionMotionSolver/pointPatchFields/derived or is there an easier solution?
Is there a tutorial for tetDecompositionMotionSolver or pseudoSolidFaceDecomposition?
running OpenFoam in parallel vishwa OpenFOAM Running, Solving & CFD 22 August 2, 2015 09:53
Running dieselFoam in parallel. Palminchi OpenFOAM 0 February 17, 2010 05:00
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 10:38
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 08:52
running multiple Fluent parallel jobs Michael Bo Hansen FLUENT 8 June 7, 2006 09:52
