May 4, 2010, 08:10 |
Couette Flow - The influence of resolution and viscosity
Emanuele
Rep Power: 17 |
Hi, i setted up a case of typic Couette flow trying to solve it with interFoam solver. Mesh generated with blockMesh (x_divisions = 20 y_divisions = 50). Changing the size of the mesh along the x axis (different x_divisions: 20 vs 40 vs 80) I obtain the same curve of U_Y in function of X coordinates when the flow is stabilized. The physical time necessary to reach the steady-state depends a lot on the discretization.
The steady state velocity profile results wrong, because it is different of the analytical solution. . I tried to modify some fvSchemes params without success (gradScheme, interpolationScheme, laplacian(muEff) ). I defined nu and rho in transportProperties : nu nu [ 0 2 -1 0 0 0 0 ] 0.066666667; rho rho [ 1 -3 0 0 0 0 0 ] 1; Acceleration force defined using file g in constant: dimensions [0 1 -2 0 0 0 0]; value ( 0 1 0 ); Furthermore, I notice that changing the viscosity the convergence values of (U_Y_max - U_Y_analytical solution)/ U_Y_analytical solution) are still the same Last edited by nuovodna; May 7, 2010 at 07:45. |
April 12, 2012, 09:47 |
Why "interFoam"?
Victor Da Palma
Rep Power: 14 |
Why did you use "interFoam"? That is a solver for 2 incompressible, isothermal immiscible fluids using a VOF (volume of fluid) phase-fraction based interface capturing approac. I am working in a simular case with "icoFoam" in a model simple 2D Couette flow (1 flow).
Greetings V. Da Palma |
reversed flow at pressure inlet and turbulent viscosity is limited.... | cfdiscool | FLUENT | 10 | June 10, 2015 07:15 |
flow with high turbulent viscosity ratio | Phillips | Main CFD Forum | 2 | August 25, 2008 19:01 |
flow with high turbulent viscosity ratio | Phillips | FLUENT | 0 | August 24, 2008 19:01 |
Question about Couette Flow | Tiger | Main CFD Forum | 1 | March 24, 2006 00:16 |
High viscosity flow | robert | Main CFD Forum | 0 | September 10, 2002 10:43 |
