wave pattern surface of floating object
Old   April 28, 2010, 09:48
Default wave pattern surface of floating object
Sören
soeren87 is on a distinguished road
hello,
I'm currently trying to simulate the flow arround an object in an air-liquid case.
My aim is getting the wave pattern.
At first I build a box with blockMesh and insert my test-hull with snappyHexMesh.
Then I use setFields to set the liquid and the air phase.
Finally I use interFoam to do the simulation.
Using paraFoam I get some results (I think my boundary conditions are wrong) but the case is running stable and I see something flowing on the hull so I will change them later.
My question: how can I build/get a wavepattern surface ?
(I am using OF 1.6)
soeren87 is offline   Reply With Quote
Old   April 29, 2010, 12:06
Gonzalo Tampier
gtampier is on a distinguished road
Don't know if I did understand what you mean. If you mean how to visualize it, your question belongs actually to the post-processing forum..
In paraview/paraFoam it's very easy. E.g.:
- contour -> select alpha=0.5
- calculator -> coordsZ (from the "scalars" button)
..and you have a nice wave elevation plot!
gtampier is offline   Reply With Quote
Old   June 19, 2010, 01:46
Ovie Doro
ovie is on a distinguished road
I tried to follow those steps, but they are not so clear to me. Could you please be more specific on the steps to follow to plot the free surface elevation?
Thanks
ovie is offline   Reply With Quote
Old   June 19, 2010, 14:10
stephane sanchi
openfoam_user is on a distinguished road
a)Run ParaFOAM
b)From the tab "properties" I select all the regions, the "updateGUI" check-box and the variables alpha1,p and U.
c)Apply "Contours" filter and set 0.5 for the alpha1 variable. In this way you have selected your free surface.
d)Apply "Calculator" filter with "Attribute Mode" selected on "Point Data". Then create a function on the scalar coordsZ.
e)Move on the "Display" tab and color by the field you have just created using the Calculator. Reset the color legend.
Depending the OF-version you use alpha1=gamma.
Or read the following thread:
http://www.cfd-online.com/Forums/ope...e-pattern.html
Best regards,
Stephane.
openfoam_user is offline   Reply With Quote
Old   June 19, 2010, 16:11
Ovie Doro
Great! Many thanks for the information. Would try this.
ovie.
Old   August 30, 2010, 10:19
Ralph Moolenaar
Ralph M is on a distinguished road
Thanks for the explanation; I've been busy with finding out how to visualize the FS for more than 2 days!
Ralph M is offline   Reply With Quote
Old   June 29, 2011, 09:34
Default OpenFOAM-2.0.x with the run-time post-processing capabilities
stephane sanchi
Dear OF-users
I'm using OpenFOAM-2.0.x with the run-time post-processing capabilities.
I would like to know where to find information to write correctly the system/isoSurface file (alpha1=0.5) ?
The motorbike tutorial has a good example but with system/cuttingPlane file.
Regards,
Stephane
Scaling up a wave energy converter - free surface flow mark_l CFX 3 February 17, 2010 17:57
Compilation error OF1.5-dev on Suse10.3 darenyang OpenFOAM Installation 0 April 29, 2009 05:55
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
Free surface wave pattern generation sam FLUENT 1 January 2, 2004 17:12
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
