OpenMPI bash: orted: comand not found error
Old   May 31, 2010, 11:23
stephane sanchi
openfoam_user is on a distinguished road
Bruno,
it works in parallel with foamJob but it is very very very slow.
I think the problem is linked with something else.
I am not able to recompile the ThirdParty-1.6.x directory !
[111]cfs10-sanchi /shared/OpenFOAM/ThirdParty-1.6.x % ./Allclean
set: Variable name must begin with a letter.
[112]cfs10-sanchi /shared/OpenFOAM/ThirdParty-1.6.x % ./Allwmake
Stephane.
openfoam_user is offline   Reply With Quote
Old   May 31, 2010, 11:33
stephane sanchi
Bruno,
yes I have run the 2 ways in the same terminal.
Hereafter is the error message with the following command :
[128]cfs10-sanchi /shared/sanchi/interDyMFoam/ras/essai % mpirun -np 6 -hostfile machines /shared/OpenFOAM/OpenFOAM-1.6.x/bin/foamExec interDyMFoam -parallel | tee log
orted: Command not found.
A daemon (pid 10888) died unexpectedly with status 1 while attempting
to launch so we are aborting.
There may be more information reported by the environment (see above).
This may be because the daemon was unable to find all the needed shared
libraries on the remote node. You may set your LD_LIBRARY_PATH to have the
location of the shared libraries on the remote nodes and this will
automatically be forwarded to the remote nodes.
mpirun noticed that the job aborted, but has no info as to the process
that caused that situation.
mpirun was unable to cleanly terminate the daemons on the nodes shown
below. Additional manual cleanup may be required - please refer to
the "orte-clean" tool for assistance.
cfs9 - daemon did not report back when launched
cfs11 - daemon did not report back when launched
Regards,
Stephane.
Old   May 31, 2010, 11:49
Retired Super Moderator
Bruno Santos
Stephane,
I've got a feeling that the problem is linked to your Linux box. If I'm not mistaken, OpenFOAM assumes that the application sh is assumed to be the same as dash, thus the weird errors you got from Allwmake and Allclean.
Additionally, also due to the Linux version you've got, the mpirun application found by foamJob and by the command line, are different!
So, I suggest trying to figure out who is seeing what... in other words:
  • to know which sh are you using:
    ls -l `which bin`
  • to know which mpirun are you using from the command line:
    ls -l `which mpirun`
  • to know which mpirun foamJob is using:
    ls -l `findExec mpirun`
These should show you to whom those names are linked to and where they are.
By the way, I missed the findExec command the first time I looked at the code I believe it's an OpenFOAM script for finding its own applications.
Best regards,
Bruno
Old   May 31, 2010, 12:03
stephane sanchi
the problem with Allwmake and Allclean is solved. I have switched between tcsh and bash.
sanchi@cfs10:~> ls -l `which mpirun`
lrwxrwxrwx 1 sanchi cfs 7 2010-05-31 12:15 /shared/OpenFOAM/ThirdParty-1.6.x/openmpi-1.3.3/platforms/linux64GccDPOpt/bin/mpirun -> orterun
sanchi@cfs10:~> ls -l `findExec mpirun`
ls: cannot access findExec:: No such file or directory
ls: cannot access command: No such file or directory
ls: cannot access not: No such file or directory
ls: cannot access found: No such file or directory
Do you mean findExec or foamExec ?
Stephane.
Old   May 31, 2010, 12:23
Bruno Santos
Looking at code in a lightning fast way tends to give bad results sometimes Sorry about that, findExec is a function in foamJob. It's a:
# replacement for possibly buggy 'which'
My guess is that this link to orterun doesn't work very well. You can check if that file really exists:
ls -l /shared/OpenFOAM/ThirdParty-1.6.x/openmpi-1.3.3/platforms/linux64GccDPOpt/bin/orterun
You better edit the foamJob script:
which foamJob
and go to the last lines and where is says:
echo "Executing: mpirun
change to
echo "Executing: $mpirun
Run foamJob like you have done before and now you will know who is foamJob really using!
Best regards,
Bruno
Old   June 1, 2010, 03:31
stephane sanchi
Hi Bruno,
the link orterun exists !
gives
-rwx------ 1 sanchi cfs 102096 2009-07-15 12:35 /shared/OpenFOAM/ThirdParty-1.6.x/openmpi-1.3.3/platforms/linux64GccDPOpt/bin/orterun
As suggested I have changed mpirun to $mpirun into the foamJob script:
[106]cfs10-sanchi /shared/sanchi/interDyMFoam/ras/essai % foamJob -s -p interDyMFoam
Parallel processing using OPENMPI with 6 processors
Executing: /shared/OpenFOAM/ThirdParty-1.6.x/openmpi-1.3.3/platforms/linux64GccDPOpt/bin/mpirun -np 6 -hostfile machines /shared/OpenFOAM/OpenFOAM-1.6.x/bin/foamExec interDyMFoam -parallel | tee log
It is strange because:
the command which mpirun gives
and the below command doesn't run :
mpirun -np 6 -hostfile machines /shared/OpenFOAM/OpenFOAM-1.6.x/bin/foamExec interDyMFoam -parallel | tee logorted: Command not found.
A daemon (pid 25028) died unexpectedly with status 1 while attempting
Regards,
Stephane.
Old   June 1, 2010, 07:56
Bruno Santos
Greetings Stephane,
gives
Like I tried to guess before, for some wicked reason, the link from mpirun to orterun isn't being properly recognized. Could be a problem related to the Linux distribution+version you are using.
Well, there are various possible solutions at hand... you can try these two commands to run mpirun:
  • Run the full command, like foamJob does:
  • Switch to orterun instead of mpirun:
    orterun -np 6 -hostfile machines /shared/OpenFOAM/OpenFOAM-1.6.x/bin/foamExec  interDyMFoam -parallel | tee log
And/or you can try to fix the link that mpirun has:
  • By copying orterun to mpirun:
    cp /shared/OpenFOAM/ThirdParty-1.6.x/openmpi-1.3.3/platforms/linux64GccDPOpt/bin/orterun /shared/OpenFOAM/ThirdParty-1.6.x/openmpi-1.3.3/platforms/linux64GccDPOpt/bin/mpirun
  • Or by making a full link:
    unlink /shared/OpenFOAM/ThirdParty-1.6.x/openmpi-1.3.3/platforms/linux64GccDPOpt/bin/mpirun
    ln -s  /shared/OpenFOAM/ThirdParty-1.6.x/openmpi-1.3.3/platforms/linux64GccDPOpt/bin/orterun  /shared/OpenFOAM/ThirdParty-1.6.x/openmpi-1.3.3/platforms/linux64GccDPOpt/bin/mpirun
Best regards,
Bruno
Last edited by wyldckat; June 2, 2010 at 09:34. Reason: had "orted" but it's suppose to be "orterun"
Old   June 2, 2010, 05:07
stephane sanchi
Hi Bruno,
Using the commands unlink and then ln -s doesn't work at all !
How it works :
1. Using foamJob -s -p interFoam
2. /shared/OpenFOAM/ThirdParty-1.6.x/openmpi-1.3.3/platforms/linux64GccDPOpt/bin/mpirun -np 4 -hostfile machines /shared/OpenFOAM/OpenFOAM-1.6.x/bin/foamExec interFoam -parallel | tee log
How it doesn't work :
1. mpirun -np 4 -hostfile machines /shared/OpenFOAM/OpenFOAM-1.6.x/bin/foamExec interFoam -parallel | tee log
A daemon (pid 17492) died unexpectedly with status 1 while attempting
mpirun: clean termination accomplished
2. /shared/OpenFOAM/ThirdParty-1.6.x/openmpi-1.3.3/platforms/linux64GccDPOpt/bin/mpirun -np 4 -hostfile machines interFoam -parallel | tee log
mpirun was unable to launch the specified application as it could not find an executable:
Executable: interFoam
Node: cfs9
while attempting to start process rank 2.
I would like to understand why, if possible.
In the past I have used the following command without problem :
mpirun -hostfile machines -np 4 interFoam -parallel > log
Regards,
Stephane.
Old   June 2, 2010, 07:36
Bruno Santos
Hi Stephane,
Was it in the very same machine? The very same linux box? Was it with the same OpenFOAM's OpenMPI version?
My guess is still what I've said before, and "unlink and then ln -s" not working are indicative that something just isn't working properly with the linking mechanism of your Linux installation.
Have you tried the copy possibility? Or did you copy first and then tried the linking possibility? I should have listed them in the opposite order... Because after copying, unlink is no longer applicable, since mpirun would no longer be a link!
Best regards,
Bruno
Old   June 2, 2010, 08:44
stephane sanchi
Bruno,
Yes, I have run in parallel with OF-1.6.x. And at least with openSUSE 11.1. Now I have openSUSE 11.2.
Maybe this can help solve my problem.
[114]cfs10-sanchi /home/sanchi/test_openmpi % ssh $HOST `which mpirun`
/shared/OpenFOAM/ThirdParty-1.6.x/openmpi-1.3.3/platforms/linux64GccDPOpt/bin/mpirun: error while loading shared libraries: libopen-rte.so.0: cannot open shared object file: No such file or directory
Regards,
Stephane.
Old   June 2, 2010, 08:54
Bruno Santos
Hi Stephane,
That's because the OpenFOAM environment isn't working on the opened ssh shell, thus LD_LIBRARY_PATH doesn't have the necessary paths for mpirun to find the necessary libraries.
Like I've asked before, have you tried copying orted to mpirun?
By copying orted to mpirun:
Best regards,
Bruno
Last edited by wyldckat; June 2, 2010 at 09:33. Reason: had "orted" but it's suppose to be "orterun"
Old   June 2, 2010, 09:07
stephane sanchi
Bruno,
I have copied *orted* to *mpirun*.
And now even the foamJob command does not work anymore.
111]cfs10-sanchi /shared/sanchi/interDyMFoam/ras/damBreak % foamJob -s -p interFoam
Parallel processing using OPENMPI with 4 processors
Executing: /shared/OpenFOAM/ThirdParty-1.6.x/openmpi-1.3.3/platforms/linux64GccDPOpt/bin/mpirun -np 4 -hostfile machines /shared/OpenFOAM/OpenFOAM-1.6.x/bin/foamExec interFoam -parallel | tee log
[cfs10:24965] Error: unknown option "-np"
input in flex scanner failed
Stephane.
Old   June 2, 2010, 09:32
Bruno Santos
Hi Stephane,
Ah %#"#"!$ ... I'm sorry, something went very wrong with my memory It's orterun not orted
To fix it:
rm /shared/OpenFOAM/ThirdParty-1.6.x/openmpi-1.3.3/platforms/linux64GccDPOpt/bin/mpirun
Or making the same relative link it use to have:
ln -s orterun /shared/OpenFOAM/ThirdParty-1.6.x/openmpi-1.3.3/platforms/linux64GccDPOpt/bin/mpirun
Hopefully, either one of these should do the trick (maybe except the last solution). Once again, I'm sorry for the typo
I'm going to fix the other posts, just in case someone else tries to run those commands
Best regards,
Bruno
Old   July 1, 2010, 07:03
stephane sanchi
Hi Bruno,
I have installed version 1.7.0. I have run some tutorials (motorbike and mixer2D) in serial and it works.
But I can't run any case in parallel.
[106]cfs10-sanchi /shared/sanchi/OpenFOAM/sanchi-1.6.x/Eole % mpirun --hostfile machines -np 4 MRFSimpleFoam -parallel > log
A daemon (pid 17287) died unexpectedly with status 1 while attempting
And now the command foamJob does not work neither !
Stephane.
Old   July 1, 2010, 07:49
Bruno Santos
Hi Stephane,
Well, you changed OpenFOAM version, but not Linux version
OpenFOAM 1.7.0 right now is almost just like 1.6.x, except for a few tweaks and addons. So, try one of steps in my previous post, but this time don't forget it's:
  • ThirdParty-1.7.0 and not ThirdParty-1.6.x;
  • openmpi-1.4.1 and not openmpi-1.3.3!
Best regards,
Bruno
Old   July 1, 2010, 09:55
stephane sanchi
Bruno,
no it doesn't work.
Always same error message.
foamJob -s -p doesn't neither.
Stephane.
Old   July 1, 2010, 10:13
Bruno Santos
OK, that Linux box doesn't seem to want to work with OpenMPI :P
Stephane do me a little favor and post what you get when you run this command:
ls -l  /shared/OpenFOAM/ThirdParty-1.7.0/openmpi-1.4.1/platforms/linux64GccDPOpt/bin
Without seeing some more clues of what the situation looks like, it'll be a lot harder to figure out what is going on!
And what comes out from these commands:
echo MPI_ARCH_PATH=$MPI_ARCH_PATH
echo OPAL_PREFIX=$OPAL_PREFIX
echo PATH=$PATH
Best regards,
Bruno
Old   July 1, 2010, 10:23
stephane sanchi
Hi Bruno,
The folder /shared/OpenFOAM/ThirdParty-1.7.0/openmpi-1.4.1/platforms/linux64GccDPOpt/bin doesn't exist.
It is located in
/shared/OpenFOAM/ThirdParty-1.7.0/platforms/linux64Gcc/openmpi-1.4.1/bin/
[116]cfs10-sanchi /home/sanchi % ls -l /shared/OpenFOAM/ThirdParty-1.7.0/platforms/linux64Gcc/openmpi-1.4.1/bin/
total 3064
lrwxrwxrwx 1 sanchi cfs 12 2010-06-30 16:56 mpic++ -> opal_wrapper
lrwxrwxrwx 1 sanchi cfs 12 2010-06-30 16:56 mpicc -> opal_wrapper
lrwxrwxrwx 1 sanchi cfs 12 2010-06-30 16:56 mpiCC -> opal_wrapper
lrwxrwxrwx 1 sanchi cfs 12 2010-06-30 16:56 mpicc-vt -> opal_wrapper
lrwxrwxrwx 1 sanchi cfs 12 2010-06-30 16:56 mpiCC-vt -> opal_wrapper
lrwxrwxrwx 1 sanchi cfs 12 2010-06-30 16:56 mpic++-vt -> opal_wrapper
lrwxrwxrwx 1 sanchi cfs 12 2010-06-30 16:56 mpicxx -> opal_wrapper
lrwxrwxrwx 1 sanchi cfs 12 2010-06-30 16:56 mpicxx-vt -> opal_wrapper
lrwxrwxrwx 1 sanchi cfs 7 2010-06-30 16:56 mpiexec -> orterun
lrwxrwxrwx 1 sanchi cfs 12 2010-06-30 16:56 mpif77 -> opal_wrapper
lrwxrwxrwx 1 sanchi cfs 12 2010-06-30 16:56 mpif77-vt -> opal_wrapper
lrwxrwxrwx 1 sanchi cfs 12 2010-06-30 16:56 mpif90 -> opal_wrapper
lrwxrwxrwx 1 sanchi cfs 12 2010-06-30 16:56 mpif90-vt -> opal_wrapper
-rwx------ 1 sanchi cfs 106795 2010-07-01 14:47 mpirun
lrwxrwxrwx 1 sanchi cfs 7 2010-06-30 16:56 mpirun.old -> orterun
lrwxrwxrwx 1 sanchi cfs 15 2010-06-30 16:56 ompi-checkpoint -> orte-checkpoint
lrwxrwxrwx 1 sanchi cfs 10 2010-06-30 16:56 ompi-clean -> orte-clean
-rwxr-xr-x 1 sanchi cfs 141953 2010-06-30 16:56 ompi_info
lrwxrwxrwx 1 sanchi cfs 8 2010-06-30 16:56 ompi-iof -> orte-iof
lrwxrwxrwx 1 sanchi cfs 7 2010-06-30 16:56 ompi-ps -> orte-ps
lrwxrwxrwx 1 sanchi cfs 12 2010-06-30 16:56 ompi-restart -> orte-restart
-rwxr-xr-x 1 sanchi cfs 18446 2010-06-30 16:56 ompi-server
-rwxr-xr-x 1 sanchi cfs 26699 2010-06-30 16:54 opal_wrapper
-rwxr-xr-x 1 sanchi cfs 267834 2010-06-30 16:56 opari
-rwxr-xr-x 1 sanchi cfs 17783 2010-06-30 16:55 orte-clean
-rwxr-xr-x 1 sanchi cfs 12105 2010-06-30 16:55 orted
-rwxr-xr-x 1 sanchi cfs 18056 2010-06-30 16:55 orte-iof
-rwxr-xr-x 1 sanchi cfs 22637 2010-06-30 16:55 orte-ps
-rwxr-xr-x 1 sanchi cfs 106795 2010-06-30 16:55 orterun
-rwxr-xr-x 1 sanchi cfs 349960 2010-06-30 16:56 otfaux
-rwxr-xr-x 1 sanchi cfs 21803 2010-06-30 16:56 otfcompress
-rwxr-xr-x 1 sanchi cfs 16337 2010-06-30 16:56 otfconfig
lrwxrwxrwx 1 sanchi cfs 11 2010-06-30 16:56 otfdecompress -> otfcompress
-rwxr-xr-x 1 sanchi cfs 185817 2010-06-30 16:56 otfdump
-rwxr-xr-x 1 sanchi cfs 173396 2010-06-30 16:56 otfinfo
-rwxr-xr-x 1 sanchi cfs 178028 2010-06-30 16:56 otfmerge
-rwxr-xr-x 1 sanchi cfs 88842 2010-06-30 16:56 vtcc
-rwxr-xr-x 1 sanchi cfs 88842 2010-06-30 16:56 vtcxx
-rwxr-xr-x 1 sanchi cfs 88842 2010-06-30 16:56 vtf77
-rwxr-xr-x 1 sanchi cfs 88842 2010-06-30 16:56 vtf90
-rwxr-xr-x 1 sanchi cfs 432965 2010-06-30 16:56 vtfilter
-rwxr-xr-x 1 sanchi cfs 581820 2010-06-30 16:56 vtunify
[104]cfs10-sanchi /home/sanchi % echo MPI_ARCH_PATH=$MPI_ARCH_PATH
MPI_ARCH_PATH=/shared/OpenFOAM/ThirdParty-1.7.0/platforms/linux64Gcc/openmpi-1.4.1
[105]cfs10-sanchi /home/sanchi % echo OPAL_PREFIX=$OPAL_PREFIX
OPAL_PREFIX=/shared/OpenFOAM/ThirdParty-1.7.0/platforms/linux64Gcc/openmpi-1.4.1
[106]cfs10-sanchi /home/sanchi % echo PATH=$PATH
PATH=/shared/OpenFOAM/ThirdParty-1.7.0/platforms/linux64Gcc/paraview-3.8.0/bin:/shared/OpenFOAM/ThirdParty-1.7.0/platforms/linux64Gcc/openmpi-1.4.1/bin:/home/sanchi/OpenFOAM/sanchi-1.7.0/applications/bin/linux64GccDPOpt:/shared/OpenFOAM/site/1.7.0/bin/linux64GccDPOpt:/shared/OpenFOAM/OpenFOAM-1.7.0/applications/bin/linux64GccDPOpt:/shared/OpenFOAM/OpenFOAM-1.7.0/wmake:/shared/OpenFOAM/OpenFOAM-1.7.0/bin:/soft/CEI/bin:/soft/intel/compiler81_fce/bin:/bin:/usr/bin:/usr/local/bin:/usr/X11R6/bin:/soft/smr/bin:/usr/bin/X11:/usr/games:/opt/kde3/bin:/home/sanchi/bin:/usr/lib64/jvm/jre/bin:/usr/lib/mit/bin:/usr/lib/mit/sbin:/soft/ParaView/ParaView3.6/bin:.:/soft/icemcfd/x86_64/linux/bin:/tmp/vos/EDGE/bin:/home/sanchi/MB-Split/bin/LINUX:/opt/mpich/bin:/soft/NTI/bin:/shared/vos/bin:/home/vos/nsmb/util/fortran2html_4.4/bin:/shared/gehri/bin:/tmp/vos/EDGE/bin:/home/sanchi/MB-Split/bin/LINUX:/soft/NTI/bin:/home/vos/nsmb/util/fortran2html_4.4/bin
Regards,
Stephane.
Old   July 1, 2010, 12:05
Bruno Santos
Hi Stephane,
It is located in
They changed places... honestly I haven't looked with much attention to OpenFOAM 1.7, although I've already built it in Ubuntu 9.10 without any issues...
OK, as for the problem you're getting... I'm getting kinda stumped as to what is going on The few things that come to mind are:
  • The path /opt/mpich/bin in PATH could be conflicting with OpenMPI's binaries for same strange reason.
  • Maybe there are other environment variables defined by default that are referent to MPICH and have names that OpenMPI also uses. The commands env or export should give you a list of all defined environment variables.
  • Try running some kind of test with OpenMPI that isn't related to OpenFOAM. I know MPICH2 has a parallel pi calculation example, but I don't know if OpenMPI has anything like that with it.
  • Have you tried running again the parallelTest application that OpenFOAM has in its test applications? But now with the 1.7 version!?
  • What does foamJob output? Is it the same error? And how does it launch mpirun (or orterun or mpiexec)?
Best regards,
Bruno
Old   July 2, 2010, 06:09
stephane sanchi
Hi Bruno,
The path */opt/mpich/bin* in *PATH* does not exist no more. But still does not run in parallel.
The *foamJob* output is :
[110]cfs10-sanchi /shared/sanchi/OpenFOAM/sanchi-1.6.x/Eole % foamJob -s -p MRFSimpleFoam
Executing: mpirun -np 4 -hostfile machines /shared/OpenFOAM/OpenFOAM-1.7.0/bin/foamExec MRFSimpleFoam -parallel | tee log
[111]cfs10-sanchi /shared/sanchi/OpenFOAM/sanchi-1.6.x/Eole %
The log file is empty.
With the *parallelTest* application the results is the same. The log file is empty.[110]cfsfs-sanchi /shared/sanchi/OpenFOAM/sanchi-1.6.x/Eole % foamJob -s -p parallelTest
Executing: mpirun -np 4 -hostfile machines /shared/OpenFOAM/OpenFOAM-1.7.0/bin/foamExec parallelTest -parallel | tee log
[111]cfsfs-sanchi /shared/sanchi/OpenFOAM/sanchi-1.6.x/Eole %
Stephane.
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 12:39
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
user defined function cfduser CFX 0 April 29, 2006 11:58
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
