interFoam 1.6.x vs 1.5 : same mesh, same bc but different results
Old   April 8, 2010, 13:03
Default Water Flow around hull ship : interFoam 1.6.x vs 1.5
Emanuele
nuovodna is on a distinguished road
Hi, i simulated a flow around an hull ship with interFoam (only water, no air and free surface). I have results with v1.5 and they seems really good. I tried to repeat the problem setting up a complete similar case in v 1.6.x but it gives me bad pressure and velocity field (all force coeffs are wrong and the simulation stopped after two days giving me an error ). I d like to know the differences between v1.5 and v1.6.x and if i setted in the wrong way the different params of simulation. I attach a pdf with the principal files.
EDIT: contours of p and U here
http://dl.dropbox.com/u/3617688/contours.tar.gz
nuovodna is offline   Reply With Quote
Old   April 13, 2010, 07:56
Default Interesting
GRD
g.redondo is on a distinguished road
This is interesting. Anyone else facing this problem? Has anyone fixed it?
OF-1.6.x has some really nice features for hull analysis, but unless we figure out what is going on with the results they're useless.
Regards,
Gonzalo
g.redondo is offline   Reply With Quote
Old   April 13, 2010, 08:21
GRD
Having a look to your files I found a couple of things that might help, but still I don't think you'll get the same results.
1. In the inlet B.C I found that setting alpha to a constant value with setFields helps convergence.
2. You should also have an atmosphere patch.
3. Try with the hull as bouyantPressure too.
Good luck, although we're still missing something. I wish there was more documentation about interFoam in 1.6.x
Gonzalo
Old   April 22, 2010, 06:46
Emanuele
i think i have to change boundary condition on pressure : if in 1.5 i have zeroGradient, in 1.6.x i have to switch on buoyantPressure on the patch orthogonal to pressure gradient. I ll keep you updated on simulation's results. Stay tuned
Old   May 3, 2010, 09:37
Emanuele
I changed the pressure boundary conditions and now p field seems good. But i have a local "dicontinuity" of U field on symmetry patch. How can i solve it?? I attach the screenshots
http://dl.dropbox.com/u/3617688/Ufield.png
http://dl.dropbox.com/u/3617688/UfieldMesh.png
Old   May 4, 2010, 06:34
Pablo
pablodecastillo is on a distinguished road
Hi Emanuele,
That is because unstrured mesh (tetras) is not working nice.
Change your mesh to hexa and if possible structured and you will see everything better.
pablodecastillo is offline   Reply With Quote
Old   June 10, 2010, 08:55
stephane sanchi
openfoam_user is on a distinguished road
Hi Emanuele,
could you put your settings for OF-1.6.x ?
Have you improve your calculation ?
Best regards,
Stephane
openfoam_user is offline   Reply With Quote
Old   June 14, 2010, 06:27
Emanuele
I have set a less value of Courant number and now it works and it's running on 4 CPUs from two weeks
Old   June 14, 2010, 06:34
stephane sanchi
Hi Emanuele,
You have a very low Courant Number !
The wigley hull of Eric Paterson runs well with Courant Number 0.8.
Regards,
Stephane.
Old   June 14, 2010, 06:45
Emanuele
Do you think i have to investigate what are wrong in other part of the case?? I thought the mesh but checkMesh is perfect...any idea??
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
interFoam with irregular Mesh luther OpenFOAM 9 August 14, 2009 08:43
incorrect results with a tetrahedral mesh jcmasters OpenFOAM 5 May 20, 2009 17:44
Mesh for 3 dim Geometry Phil FLUENT 9 July 12, 2000 05:39
Mesh Mignard FLUENT 2 March 22, 2000 06:12
