April 7, 2010, 18:04 |
Spalart-Allmaras boundary condition
Rep Power: 17 |
I have a few questions about Spalart-Allmaras model, I applied it to an airfoil (blade section of a marine propeller).
1. I guess a turbulent viscosity ratio equal to 1, so nut = nu. I don't find a shared opinion about nuTilda: nuTilda = 3 * nu? nuTilda = 5 * nu? Maybe it's not so important. 2. Wich is the best range for y+? 3. My reference case is 2DAirfoil tutorial (incompressible/simpleFoam). I don't know the meaning of freestreamPressure or freestream BC types, I've used fieldValue or zeroGradient so far. Could you explain this to me? For istance, I used (k-w SST model): inlet: p = zeroGradient; U = uniform (7.30 0 0); k = uniform 0.24; omega = uniform 1.78 outlet: p = uniform 0; U = zeroGradient; k = zeroGradient; omega = zeroGradient; wall: p = zeroGradient; U = uniform (0 0 0); k = uniform 0.24; type: kqRWallFunction; omega = uniform 1.78; type: kqRWallFunction; side: p,U,k,omega = symmetryPlane; frontAndBack: p,U,k,omega = empty; Thanks for your help (and patience). |
April 16, 2010, 09:17 |
Rep Power: 17 |
I really don't understand. For external flows, FLUENT suggests =1-10, ESI a range of 0.1-0.2, other sources about Spalart-Allamaras model suggest a 0.1 value... help me, please!
April 3, 2013, 12:53 |
Malik
Rep Power: 13 |
Hi !
I really don't understand how to set the BC for the Spalart model either. What I read in the litterature explains that it is suitable to choose something between 3*nu and 5*nu. On the wiki, you can also find a formula which depends on the turbulent length scale and the turbulence intensity. When I apply it for a cylinder in a wind tunnel of turbulence intensity of 1%, a turbulence length scale of 0.11m (estimated with the dimensions of the wind tunnel used by Roschko), and for a velocity of 15 m/s, I have nutilda/nu >> 5 Conclusion 1: my flow, is not fully turbulent... But lets make it more turbulent : we will have to increase velocity. But if we increase it, nutilda is going to increase, and never come closer to 5*nu Conclusion 2 : there is something I don't understand on the way you choose the Spalart BC. If anyone has an idea, I would be very delighted to hear it ! thanks in advance ! |
How exactly the "pressure outlet" bdry condition compute properties on the boundary? | yating9901 | FLUENT | 3 | June 28, 2010 13:26 |
Transient outlet boundary condition problem | jwillie2000 | CFX | 1 | December 7, 2009 18:07 |
Axis Boundary Condition..what is it? | CFDtoy | FLUENT | 6 | February 13, 2007 06:51 |
How to set boundary condition in Fluent for the fo | Peiyong | FLUENT | 1 | November 10, 2006 12:44 |
How to resolve boundary condition problem? | sam | FLUENT | 2 | July 20, 2003 03:19 |
