1.6.x: Adaptive wall function: BoundaryFoam Tutorial |
March 30, 2010, 05:43 |
BastiL
Rep Power: 20 |
following this thread: http://www.cfd-online.com/Forums/ope...megasst-2.html I am trying to run the BoundaryFoam tutorial with Adaptive wall functions:
Selecting RAS turbulence model kEpsilon #0 Foam::error::printStack(Foam::Ostream&) in "/opt/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/opt/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #2 ?? in "/lib64/libc.so.6" #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/opt/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #4 Foam::operator/(Foam::tmp<Foam::Field<double> > const&, Foam::UList<double> const&) in "/opt/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #5 Foam::incompressible::RASModels::nutSpalartAllmarasWallFunctionFvPatchScalarField::calcNut() const in "/opt/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libincompressibleRASModels.so" #6 Foam::incompressible::RASModels::nutWallFunctionFvPatchScalarField::updateCoeffs() in "/opt/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libincompressibleRASModels.so" #7 Foam::fvPatchField<double>::evaluate(Foam::Pstream::commsTypes) in "/opt/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/boundaryFoam" #8 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::evaluate() in "/opt/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/boundaryFoam" #9 Foam::incompressible::RASModels::kEpsilon::kEpsilon(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&) in "/opt/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libincompressibleRASModels.so" #10 Foam::incompressible::RASModel::adddictionaryConstructorToTable<Foam::incompressible::RASModels::kEpsilon>::New(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&) in "/opt/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libincompressibleRASModels.so" #11 Foam::incompressible::RASModel::New(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&) in "/opt/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libincompressibleRASModels.so" #12 main in "/opt/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/boundaryFoam" #13 __libc_start_main in "/lib64/libc.so.6" #14 __gxx_personality_v0 in "/opt/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/boundaryFoam" Floating point exception The latest 1.6.x also have pure LowRe Nut Wall functions. Changing nutWallFunction to nutLowReWallFunction everything is running fine... Ideas? Regards Bastian |
May 18, 2010, 19:20 |
Hi Bastian,
I have the same issue when running my own case with the nutSpallartAll..WallFunction. And setting to nutLowReWallFunction everything runs fine. Thus for now, I will simply use the LowRe function... However, I don't know what is the issue. Good luck with that, -Louis |
May 19, 2010, 19:20 |
Ok I solved it. It works now.
EDIT: false alarm, I had made a typo in the name and wrote it as nutSpallartAllmarasWallFunction, which made it run, but.. improperly... Last edited by louisgag; May 20, 2010 at 17:45. |
May 21, 2010, 04:49 |
#4 | |
BastiL
Rep Power: 20 |
I did not have the time to check but there were changes of the wall functions pushed into git after I stated this thread. Which version did you use? Regards Bastian |
May 25, 2010, 14:11 |
Hi Bastian.
- For my version number I couldn't find it; however, it dates from around early april. - For the typo in "SpallartAllmaras" I found that if you give any weird name the same model is used, probably some default wall model. It is not nutWallFunction. - For the working nutSpalartAllmarasWallFunction, try setting your wall U value to something like Code:
(1e-10 0 0) -Louis |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 10:31 |
Need some wall function approaches! | yka8150 | Main CFD Forum | 0 | September 22, 2009 00:08 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
Wall function | tod | Phoenics | 1 | May 19, 2003 06:05 |
Wall function in adverse pressure gradients | stephane baralon | Main CFD Forum | 11 | September 2, 1999 05:05 |
