Help me to solve a basic heat transfer problem |
March 28, 2010, 07:38 |
:hello FOAMers
i want solve a canal and obtain temperature contour for its solid container. convective heat transfer is internally (Forced) and externally (Natural) exists. i produced mesh as standard OpenFOAM format. I know i should use laplacianFoam of basic dir. BUT i don't know how should i solve this problem. Best |
March 28, 2010, 09:51 |
Sebastian Gatzka
Rep Power: 20 |
I suppose you meshed only the container (what is that exactly to you?) because this is all you are interested in?
Than you should use convective boundary conditions on both sides.
Schrödingers wife: "What did you do to the cat? It's half dead!" |
March 28, 2010, 16:49 |
#3 | |
Yes i've meshed the solid container of canal. my problem is what changes should i do on run/tutorials/basic/laplacianFoam dir to achieve a solution for my desired canal problem. i am new and it is my first FOAMing. |
April 2, 2010, 08:14 |
Sebastian Gatzka
Rep Power: 20 |
Well, as mentioned above you should change the boundary conditions.
Make yourself comfortable with heat transfer, so you can decide which condition suits your problem best: http://web.mit.edu/lienhard/www/ahtt.html Changing the boundary conditions you should be able to do, once you have read the User Guide. Get back to us ...
heat transfer in egg - problem | Tiggr | FLUENT | 1 | June 24, 2009 10:55 |
A simple heat transfer problem ? | iggor | FLUENT | 1 | June 15, 2009 05:42 |
How can I increase Heat Transfer at Domain Interf? | B.Simon | CFX | 3 | October 28, 2008 19:53 |
Electrolyte heat transfer problem | fea user | CFX | 0 | November 28, 2006 18:39 |
regarding B.C. of Heat transfer problem | Manoj Padmakarrao Raut | Siemens | 0 | March 17, 2005 01:01 |
