forces on a hydrofoil
Old   March 26, 2010, 08:57
Default forces on a hydrofoil
vaina74 is on a distinguished road
I included a subroutine in the controlDict file to evaluate the lift and drag coefficients on a blade section of a marine propeller:
functions
forces
type forces;
functionObjectLibs ("libforces.so"); // Lib to load
patches (wall); // change to your patch name
rhoName rhoInf;
rhoInf 1025; // Reference density for fluid
CofR (0 0 0); // Origin for moment calculations
forceCoeffs
type forceCoeffs;
rhoName rhoInf;
rhoInf 1025;
CofR (0 0 0);
liftDir (0 1 0);
dragDir (1 0 0);
pitchAxis (0 0 0);
magUInf 7.30;
lRef 0.305;
Aref 0,00306;
I set the hydrofoil chord as lRef and the wetted surface as Aref (or is Aref its projection on the chord?) and this is the output:
[0]
[0]
[0] keyword outputControl is undefined in dictionary "::functions::forces"
[0]
[0] file: ::functions::forces from line 56 to line 60.
[0]
[0]     From function dictionary::lookupEntry(const word&, bool, bool) const
[0]     in file db/dictionary/dictionary.C at line 388.
[0]
FOAM parallel run exiting
[0]
[1]
[1]
[1] keyword outputControl is undefined in dictionary "::functions::forces"
[1]
[1] file: ::functions::forces from line 56 to line 60.
[1]
[1]     From function dictionary::lookupEntry(const word&, bool, bool) const
[1]     in file db/dictionary/dictionary.C at line 388.
[1]
[1]
What's the problem, please?
vaina74 is offline   Reply With Quote
Old   March 28, 2010, 17:09
Smile
maddalena's Avatar
maddalena
maddalena will become famous soon enough
you missed one keyword! See here: http://www.cfd-online.com/Forums/ope...ing-1-6-a.html
Cheers,
maddalena
maddalena is offline   Reply With Quote
Old   March 29, 2010, 13:49
Thanks, Maddalena. First I merged all the threads about lift and drag, then I found the nacaAirfoil tutorial (in compressible/sonicFoam/ras). I included in my controlDict:
functions
    forces
        type        forces;
        functionObjectLibs ( "libforces.so" );  // lib to load
        outputControl timeStep;
        outputInterval 1;
        patches
            wall  // change to your patch name
        // name of fields
        pName       p;
        UName       U;
        log         true; // dump to file
        rhoInf      1025;
        CofR        ( 0 0 0 );
    forcesCoeffs
        type        forceCoeffs;
        outputInterval 1;
        patches
        // name of fields
        pName       p;
        UName       U;
        rhoInf      1025;
        CofR        ( 0 0 0 );
        liftDir     ( 0 1 0 );
        dragDir     ( 1 0 0 );
        pitchAxis   ( 0 0 0 );
        magUInf     7.30;
        lRef        0.305;
        Aref        0.001525;
I'm still in doubt: is Aref the projection of the area on the chord or the whole wetted surface?
Old   March 29, 2010, 17:10
maddalena's Avatar
maddalena
Ehi Vaina,
Is Aref the projection of the area on the chord or the whole wetted surface?
Well, I do not know if something changes with hydrofoils. In any case, the definition of aerodynamic force coefficient for an airfoil (2d) is c_F = F/(0.5 * rhoInf * v_inf^2 *c), thus I would set Aref = 1. What do you think?
Cheers,
maddalena
Old   March 30, 2010, 07:19
I know the lift (or drag) equation is:
C_L= \frac{L}{\frac{1}{2}{\rho}v^2A_{ref}}
where A_{ref} is planform area. In the section lift coefficient (based on the concept of an infinite wing of non-varying cross-section), the lift is defined per unit span of the wing:
c_l= \frac{L}{\frac{1}{2}{\rho}v^2c}
In OpenFOAM all geometries are generated in 3 dimensions and my hydrofoil span is 0.05 mm. So I think A_{ref} is equal to c\cdot span.
Old   March 30, 2010, 08:30
Thumbs up
maddalena's Avatar
maddalena
Perfect!
Reading forces from previous time step within solver SD@TUB OpenFOAM Programming & Development 5 April 24, 2023 12:51
Forces calulated through pressure LVDH OpenFOAM Post-Processing 2 February 26, 2010 04:15
Calculate forces without hydrostatic pressure geir_oye FLUENT 4 November 12, 2009 10:12
changes to forces in 1.6 linnemann OpenFOAM Running, Solving & CFD 0 July 30, 2009 09:49
Valve Forces in CFdesign Mike Clapp Main CFD Forum 3 March 8, 2001 15:09
