Does FOAM converge to exact solution in Laplace equation?
Old   March 26, 2010, 08:52
Default Does FOAM converge to exact solution in Laplace equation?
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Recently Nisi and me have been working in understanding the nonOrthogonal correction method implemented in FOAM. As have been explained in another threads Over-Relaxed approach is used to correct the solution iteratively for non-orthogonal meshes. We carried out several runnings with the same problem but incresing non-orthogonality. The mesh was simple, a bar with only two triangular (wedge) elements, and different large-height ratio. Since the equation was the Laplace one and temperatures fixed at both extremes, analytical solution is a line and we could compare it with the numerical data. We've found that numerical solution converges but not to the analytical solution, and this phenomenon is so big as the non-orthogonality is. Nisi have found the following errors for different mesh ratios (for 9 nonOrthogonalCorrections):
Mesh ratio %e
2:1 0.1135 %
5:1 0.53375 %
20:1 1.2209 %
Is that interpretation correct? If it is correct is the approach based in any kind of compromise solution or what is the idea behind it (remember that even solution is fairly good, this approach would violate one the cornerstones of numerical analysis --> convergence to analytic solution) ?
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
CFL Condition Matt Umbel Main CFD Forum 19 June 30, 2020 09:20
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 05:38
Exact 2D NS solution for benchmarking? Tony Main CFD Forum 4 July 31, 2001 15:50
Analytical solution to the 3d Laplace equation Chrys Correa Main CFD Forum 4 September 11, 2000 19:50
