turbDyMFoam settings
Old   March 18, 2010, 10:52
Default turbDyMFoam settings
Michael Buchmayr
MichiB is on a distinguished road
Hi everybody!
we are trying to calculate the transient turbulent flow through a pump, yet with little success. We where using turbDymFoam, with a uniform (p and U) initial calculation domain. The calculation somehow diverges, and we can't figure out why.
The fvSchemes we set look as follows:
ddtSchemes
default Euler;
gradSchemes
default Gauss linear;
grad(p) Gauss linear;
grad(U) Gauss linear;
divSchemes
default none;
div(phi,U) Gauss linearUpwind Gauss;
div(phi,k) Gauss upwind;
div(phi,epsilon) Gauss upwind;
div(phi,omega) Gauss upwind;
div(phi,R) Gauss upwind;
div(R) Gauss linear;
div(phi,nuTilda) Gauss upwind;
div((nuEff*dev(grad(U).T()))) Gauss linear;
laplacianSchemes
default none;
laplacian(nuEff,U) Gauss linear corrected;
laplacian((1|A(U)),p) Gauss linear corrected;
laplacian(DkEff,k) Gauss linear corrected;
laplacian(DepsilonEff,epsilon) Gauss linear corrected;
laplacian(DomegaEff,omega) Gauss linear corrected;
laplacian(DREff,R) Gauss linear corrected;
laplacian(DnuTildaEff,nuTilda) Gauss linear corrected;
laplacian(rAU,p) Gauss linear corrected;
laplacian(rAU,pcorr) Gauss linear corrected;
laplacian(nu,U) Gauss linear corrected;
interpolationSchemes
default linear;
interpolate(U) linear;
interpolate(HbyA) linear;
interpolate(1|A) linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p;
pcorr;
We now wanted to initialize the field with a steady state solution using MRFSimpleFoam. But again -> ocillating residuals.
Does anybody have an idea what we could have done wrong?
MichiB is offline   Reply With Quote
Old   March 18, 2010, 10:54
Michael Buchmayr
Forgot the solution schemes
solvers {
p PCG {
preconditioner DIC;
tolerance 1e-05;
relTol 0.0002;
minIter 2; maxIter 5; };
pFinal PCG {
preconditioner DIC;
tolerance 1e-05;
relTol 0.0001;
U BiCGStab {
preconditioner { type DILU; }
minIter 1; maxIter 10;
tolerance 1e-07;
relTol 0; };
k BiCGStab { // and epsilon
minIter 1; maxIter 5;
tolerance 1e-07;
relTol 0; };
epsilon BiCGStab {
tolerance 1e-07;
relTol 0; };
omega BiCGStab {
tolerance 1e-07;
relTol 0; };
R GAMG
preconditioner GAMG;
tolerance 1e-06;
relTol 0.1;
agglomerator faceAreaPair;
nCellsInCoarsestLevel 10;
mergeLevels 1;
smoother GaussSeidel;
minIter 0;
maxIter 100;
cacheAgglomeration true;
nPreSweeps 0;
nPostSweeps 2;
nFinestSweeps 2;
nuTilda GAMG
tolerance 1e-06;
relTol 0.1;
mergeLevels 1;
minIter 0;
maxIter 100;
nPreSweeps 0;
nPostSweeps 2;
nFinestSweeps 2;
SIMPLE
nNonOrthogonalCorrectors 2;
PISO
momentumPredictor no;
nCorrectors 3;
nGammaCorr 1;
nGammaSubCycles 4;
cGamma 1;
relaxationFactors
p 0.3;
U 0.7;
k 0.7;
epsilon 0.7;
omega 0.7;
R 0.7;
nuTilda 0.7;
Old   August 4, 2010, 09:14
Nick Gardiner
NickG is on a distinguished road
Hi
Try running turbFoam on it first to get reasonable values for k and epsilon.
I have momentumPredictor yes; in my PISO loop. Don't know if that's going to make a difference but the initial turbulence model variables certainly affect the stability.
Good luck
NickG is offline   Reply With Quote
BC settings to expand pressure on atmosphere - simpleFoam / totalPressure sErik OpenFOAM Running, Solving & CFD 1 June 15, 2011 03:49
update turbDyMFoam antonio_ing OpenFOAM Installation 12 June 2, 2010 09:16
Export settings in the material panel sebastian FLUENT 1 November 18, 2009 06:11
Default settings for 3D boundary layer-Gambit 2.2 Ramine FLUENT 1 July 31, 2006 13:36
help on memory settings in TASCflow Dr C.Bhasker CFX 1 September 5, 2001 06:57
