Rotor-stator computation with Ggi interface (turbDyMFoam)
Old   May 25, 2010, 13:58
Eric Nutsch
ericnutsch is on a distinguished road
Send a message via Skype™ to ericnutsch
Hello Aldo,
Originally Posted by aldo.iannetti View Post
I'm studing a vertical axis wind turbine 2D, I have an internal-rotational zone and an external-static zone and the interfaces have been modelled as GGI.
Me too! Sounds like we are at about the same stage of testing as well.
So does your ggi model work without the turbulence model?
I have gotten a k-e turbulence model to work with the ggi. Once I know more specifically where your hung up I can help.
Im in the process of testing the ggi interface with the turbulence model and so far so good.
Ive signed an NDA on the VAWT design, but I would certainly like to correspond on our solving methods; ericnutsch@gmail.com
ericnutsch is offline   Reply With Quote
Old   May 26, 2010, 07:06
Nick Gardiner
NickG is on a distinguished road
Hi Aldo
I don't bother to specify a value for any of the /0/ files - just: type ggi;
The important part is specifying correct values for k and epsilon (or omega)
My understanding is that you set the internalField as:
for k:
1.5(magUI)^2 where magU is the magnitude of the velocity
I is the turbulence intensity
for epsilon:
(Cmu^0.75)(k^1.5)/L where Cmu =0.09 (see /constant/RASProperties)
k is worked out through previous
L is the characteristic length that you'd use for the Reynolds number
for omega if you need it later:
(Cmu^-0.25)(k^0.5)/L
Good luck! Let us know if it works
Nick
NickG is offline   Reply With Quote
Old   June 8, 2010, 08:59
Default GGI for HAWT
  #23
Antoine Devesa
A.Devesa is on a distinguished road
Hi all,
i'm simulating the propeller of an HAWT using GGI / turbDyMFoam, and i'm quite surprised that the wake of my blades is almost unexisting (e.g. no wing-tip structures) for a lambda of around 7 (lambda = Vwingtip / Vinf)...
Could you please briefly share your experience on GGI for simulating WT?
- Which turbulence model are you using?
- Which BC on the rotating elements?
- Which lambda?
- Which level of initial / inlet turbulence?
- Are you satisfied of your results?
Thank you for your answers!!
Antoine
A.Devesa is offline   Reply With Quote
Old   June 8, 2010, 14:24
Eric Nutsch
You are a bit ahead of me. I am currently modelling in 2D with a k-epsilon model. I have yet to confirm its performance with wind tunnel testing, but I will keep everyone posted.
You may want to test that the turbulence values are passing the interface at all, or if there is a time delay. This will give you an idea of where the issue lies...
For 3D i believe you will want to use a LES turbulence model, but i have not tested any with the ggi.
Old   June 9, 2010, 06:31
Antoine Devesa
Ok, thanks for keeping posting, it's really interesting.
On my side, i want first to success using RAS approach, before i go to LES. Moreover it's actually not yet possible to use GGI in comibnation with LES, is it?
Any other experience to share, concerning 3D RAS simulations of WT with GGI and turbDyMFoam?
Old   June 10, 2010, 08:18
Question does turboDyMFoam work in OF-1.6
  #26
shyam prasad
shyam is on a distinguished road
Hi Foamers,
Does turboDyMFoam work in OF-1.6?
shyam is offline   Reply With Quote
Old   June 10, 2010, 12:58
Nick Gardiner
Hi Shyam - I'm afraid not.
Old   January 12, 2011, 20:58
Jie
jiejie is on a distinguished road
Originally Posted by Stylianos View Post
I think i found what my mistake was. It seems the name of the rotating domain in cellZones is hardcoted in the code as movingCells.
So you just have to go in constant/polymesh/cellZones and rename the whatever name of your rotating domain into movingCells.
Stelios
Dear Stelios
After I renamed it into movingCells and ran the simulation, I found that the stator is rotating as well. Then I compared the 3d case with 2d case for a very simple rotating block case, i found after I convert the fluent mesh to the OpenFOAM conpatable, the cellZones (should only include the cells from rotator only) include all the cells from both stator and rotor, which causes such problem.
Have you experienced this before? Will it be due to the meshing problem? I used the icemcfd.
I have upload the case at http://www.megaupload.com/?d=2IIU3UVC
Really appreciate if you can have a look at it.
jiejie is offline   Reply With Quote
Old   January 12, 2011, 21:37
Jie
I am not sure whether it is the meshing problem or not. Now I can make the stator to be stationary by re-initialise the /constant/polyMesh/cellZones with the followings:
FoamFile
version 2.0;
format ascii;
class regIOobject;
location "constant/polyMesh";
object cellZones;
0
Then, the cellZones will be re-written with the celld from rotor part.
Cheers
ggi, segmentation fault, turbdymfoam
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
GGI (General Grid Interface) Connections feixiangniao CFX 4 January 14, 2010 20:51
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
CFX GGI Interface Error (non-overlapping) surge519 CFX 1 August 3, 2009 19:54
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
