January 13, 2021, 05:10 |
Marangoni convection
#21 | |
Rep Power: 6 |
In the VOF method and Marangoni convection post, I learned that you implemented tangential surface tension in the phase System library of icoReactingMultiphaseInterFOAM. I'm having trouble implementing it, can you please tell me how? |
June 3, 2021, 12:52 |
#22 | |
Rep Power: 5 |
how did you manage the Implementaion? Currently, Im starting to work on the same Problem. |
June 3, 2021, 13:59 |
#23 |
Sebastian
Rep Power: 12 |
Dear Fellow-Foamers,
I received a lot of requests about the tangential surface tension force implementation both in icoReactingMultiphaseInterFoam and condensatingEvaporatingFoam. They both give the exact same results and have been tested with 2 different testcases more or less successfully. Unfortunately, I'm still not allowed to share the code here without publishing it beforehand. I will, however, try to get the permission to share it with you guys asap. It would be nice if we could test and improve it further. Together! So please excuse the delay and stay tuned! |
June 3, 2021, 23:12 |
#24 |
Rep Power: 5 |
That's amazing to hear.
February 2, 2022, 09:52 |
#25 |
Rep Power: 6 |
Dear all, I have successfully implemented the Marangi effect in the icoReactingMultiphaseInterFoam solver. If you want to know, how this can be done, you can read that in our most recent publication: https://iopscience.iop.org/article/1...61-651X/ac4a26
April 27, 2022, 20:31 |
Marangoni
#26 | |
Anonymous.
Rep Power: 6 |
Your version is under ESI which I'm not sure 100% is compatible with OF8/9. |
April 28, 2022, 06:06 |
#27 |
Teresa
Rep Power: 10 |
Hi gentodin,
as far as I know icoReactingMultiphaseInterFoam is not available in OF8/9 and it might be a lot of work to implement it. Please correct me if I am wrong. If I may ask, why do you want to use OF8/9? Or do you just want the Marangoni Effect with OF8/9 specific solvers? Regards, Teresa |
May 21, 2022, 13:15 |
Compilation and test case
#28 | |
Berin Šeta
Rep Power: 11 |
I wonder how did you compile newly modified phasesystem file and called it by icoReactingMultiphaseInterFoam? Did you had to change anything apart of that phasesystem file to run those cases from the article? Moreover, could you share benchmark test case file by Sen&Davis? I would like to know how you defined dsigma/dT in your case. Best regards, Berin |
May 23, 2022, 05:28 |
#29 |
Rep Power: 6 |
Hi Berin,
I copied the icoReactingMultiphaseInterFoam solver, changed its name, made the changes in the source files and compiled it. That's all. Attached you can find the benchmark test case files. There, I named the new solver floWSolver2. With the current implementation, you don't specify dsigma/dT, but a table with temperatures and corresponding surface tension values. Best regards, Florian |
August 25, 2022, 02:52 |
Of8
#30 | |
Anonymous.
Rep Power: 6 |
I chose to work with OF8 initially as I obtained training for it specifically. The other training under ESI I did not realize it until I have already implemented most of my physics. Nevertheless, I figured out how to implement the physics already. Cheers. |
October 21, 2022, 01:47 |
#31 | |
VINIT
Rep Power: 4 |
Hello Florian I am trying to implement marangoni by adding the equation to phasesystem file but it is a read only file. Could you please let me know how you did you do it? Is there something I am missing? |
October 21, 2022, 03:02 |
#32 |
Teresa
Rep Power: 10 |
User rights of files are changed with system specific commands. So you could google with the info what system you are using and find out how to change the permissions for the file. Often it makes sense to save files before changing them or to change only copies.
August 10, 2023, 06:28 |
#33 |
Krishna Thombare
Rep Power: 3 |
can you please explain what "kappa" means in this formula?
Thank you. |
August 10, 2023, 06:46 |
#34 |
Rep Power: 6 |
"Kappa" usually denotes the interface curvature.
marangoni vof |
