3D dam breaking in a box
Old   February 25, 2010, 03:07
Default 3D dam breaking in a box
Ping-Chen Wu
koWUalsky is on a distinguished road
Hi, everyone,
I am just a beginner on using OF. I made a "3D dam breaking in a box" for practice.
Here is the animations I made,
http://sites.google.com/site/kowualsky/3dKEdamBreak.wmv
http://sites.google.com/site/kowuals...EdamBreak2.wmv
It used the k-epsilon turbulence model.
I am wondering that in VOF, the freesurface should be at alpha=0.5, right? But in this case i made, the iso-surface of alpha=0.5 is very strange. It seems alpha=0.9 or 0.99 (as i shown in the animations) is better to represent the free surface. Why?
And, the result may be beautiful. It showed the bubble and splash. They will go back to freesurface. Basically, the flow field is symmetric against x=z. But I am also wondering that when bubbles rise back to the freesurface, they should produce jet, right?
Best regards,
Wu
koWUalsky is offline   Reply With Quote
Old   February 26, 2010, 06:30
ata
ata's Avatar
ata kamyabi
ata is on a distinguished road
Dear koWUalsky
Hello
Because of my low speed internet connection I can't download your films but it is true, alfa=1 is interface.
Best regards
ata is offline   Reply With Quote
Old   February 26, 2010, 16:43
Ping-Chen Wu
Dear ata,
Thanks for your reply. Now, the data is not avarible for me. But I will show some pics after back to my lab.
Maybe my setting is something wrong.
For choosing alpha=0.5, it got reasons. I had a little experience in Fluent. We wanted to verify its VOF by computing the submerged foil. Compared with experient (from Dr. Duncan) and level-set method (from Dr. Young and Dr. Stern), the alpha=0.5 matched well. So, it should be alpha=0.5.
Plus, I thought that because of no clear interface for defining the free surface in VOF, it is a distribution, the free surface should be located beween air and water. So, the alpha=0.5 makes sense. The alpha=1.0 means it is totally water.
Recently, I also try to learn the simulation of wave elevation surrounding the ship. I download and refer the OF tutorial made by Dr. Paterson's lab. They also suggest the alpha=0.5 as the free surface.
Actually, I always think about definition of the free surface in VOF. Theoretically, the interface for being the free surface should satisfy the free surface kinematic and dynamic condition. But in VOF, it didn't consider this part explicitly. The level-set method solves this part, but VOF doesn't.(However, the single-phase level set method doesn't consider the air flow field, but VOF does.) We might or should find the streamline which satisfies the free surface conditions. it may not be easy. Then, it would be the free surface. So, I am thinking that if the alpha=0.5 is a streamline, it should be the free surface. It is a streamline and the free surface, right?
Best regards,
Wu
Old   February 27, 2010, 00:40
ata
ata's Avatar
ata kamyabi
Dear Ping-Chen Wu
Hello. I hope you are well.
As you know because of numerical diffusion, in VOF method there is not an strict interface between fluids especially in long times. If numerical method hasn't numerical diffusion alfa=0.5 and alfa=1 are almost same but in common cases that numerical diffusion exist it seems that you are right and it is better to select alfa=0.5 as interface.
For your last question as I see, if there is no normal velocity to the free surface, free surface is stream line, else, it in not.
All the best
Ata
CFD Animations of breaking waves Dommermuth Main CFD Forum 0 June 17, 2009 12:47
[OpenFOAM] Visualization of breaking of a dam tutorial lasb ParaView 2 July 13, 2007 09:15
Immersol Simulation of a Heated Box Dong Phoenics 0 March 2, 2006 22:20
Dam Breaking Problem B Godderidge Siemens 0 May 19, 2005 05:35
Diverge in 2d dam breaking case Jason FLUENT 0 November 1, 2002 04:12
