Low temp. (~ 300 K) turb. jet & JANAF problems
Old   February 11, 2010, 19:50
Default Low temp. (~ 300 K) turb. jet & JANAF problems
Bart Weisser
bart_weisser is on a distinguished road
Hello there:
I am trying to use reactingFoam to simulate NG injection / ignition / combustion in a combustion chamber. When it injects (even at low velocity), the expansion causes temperature to go below the lower JANAF range (which is 200 K).
I tried to trick reactingFoam by changing the JANAF temperautre bounds (in constant/thermo.properties) to 0K to 50000K, but it looks like some kind of downward spirl, and the solver would eventually reach temepratures beyond the bounds.
Is there a way to use something other than the JANAF tables given here?
Thanks, Bart.
bart_weisser is offline   Reply With Quote
solver problems at extreme low velocities matthias CFX 4 September 4, 2006 06:03
Jet penetration problems Ahmad CFX 6 May 6, 2006 12:51
Low Inlet Turb. Intensity - SST model not converge Pete CFX 0 November 12, 2005 02:26
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
jet oscillation at low inlet Re wood Main CFD Forum 1 October 21, 1999 14:45
