Problems with the density at walls for a compressible flow
Old   February 8, 2010, 13:33
Default Problems with the density at walls for a compressible flow
david39 is on a distinguished road
Dear all,
I am trying to run a simulation for a compressible flow in a pipe by using the Launder-Sharma K-Epsilon turbulence model in the version 1.5-dev from OpenFOAM (I have some interfaces in my mesh).
For this simulation, I use a compressible solver : rhoPorousSimpleFoam and I have defined the following boundary conditions :
- Inlet : total pressure
- Outlet : static pressure
- Wall : k and epsilon = 1.e-20 (Launder-Sharma k-Epsilon model), and for p and T, I use the type zeroGradient.
For this simulation, I use a relaxation factor from 0.05 for the density.
My problem is that, after some iterations, the density becomes more and more higher and I can obtain values up to 100 (and more) for the density.
By using Paraview for the postprocessing, I have seen that the high densities are at the walls (the first cells at the walls) but I do not understand why.
I already have remeshed my geometry to try to get a better mesh (orthogonal cell at the walls) but the problem persists.
I already have increased the number of nNonOrthogonalCorrectors but the problem persists.
To reproduce my problem, I have meshed a straight pipe and used the same setup. With the straight pipe (hexahedra), there is no problem and with a complex geometry (hexcore mesh from Tgrid), I do not understand what happens.
I presume that there are some problems with my setup but I do not understand where.
Do you have any idea ?
Thanks.
Best regards,
David
david39 is offline   Reply With Quote
Compressible Fluid Flow in COMSOL Multiphysics BBG COMSOL 1 November 19, 2008 15:05
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
momentum under-relaxation for compressible flow with SIMPLE Mihai ARGHIR Main CFD Forum 0 April 7, 2000 05:58
compressible channel flow.. R.D.Prabhu Main CFD Forum 0 July 17, 1998 18:23
