nut and nuTilda
Like Tree43Likes
Old   August 29, 2013, 11:10
vishal
vishal_s is on a distinguished road
Hello Everyone, did u got the correct interpretation for X??
vishal_s is offline   Reply With Quote
Old   October 18, 2013, 08:26
aerogt3 is on a distinguished road
Same, question here, and how to calculate it from freestream turbulence properties!
aerogt3 is offline   Reply With Quote
Old   July 15, 2014, 04:15
Default nut
  #23
Albrecht vBoetticher
vonboett is on a distinguished road
well X is specified as nutilda/nu, nutilda as zero on walls and aswell zero in the free stream, but for stability reasons values fo nutilda < 0.5 nu can be applied. In case you only need it as a starting value (and I think this is the case for Hybrid URANS_LES DES, DDES using Spalart-Allmaras) wikipedia suggests to use nutilda = 5nu in the free stream, which causes turbulence to develop whereever shear flow occurs. (see http://www.cfd-online.com/Wiki/Turbu...ary_conditions)
Mojtaba.a likes this.
vonboett is offline   Reply With Quote
Old   November 6, 2014, 05:27
Default about nut
  #24
SCG
SANGAMESH
SCG is on a distinguished road
what value i have to mention in nut file for outlet
SCG is offline   Reply With Quote
Old   November 29, 2014, 22:34
tareqkh's Avatar
CFD
tareqkh is on a distinguished road
since you already got it, could you please share it.
Regards,
tareqkh is offline   Reply With Quote
Old   December 31, 2014, 19:55
Altan
alyucel is on a distinguished road
Originally Posted by Philer View Post
I was really confused since the nuTilda file exists even with kEpsilon models in the tutorial. Now I know it is superfluous.
Thank you, guys!
Phile
This question was not answered yet
nut> dynamic turbulence viscosity
nutilda> kinamatic turbulence viscosity
aren't they?
and what is the different ?
alyucel is offline   Reply With Quote
Old   January 4, 2015, 21:54
Eric Robertson
msuaeronautics is on a distinguished road
aren't they?
The field "nuTilda" is a pseudo turbulent viscosity, which is solved for through a transport equation in all Spalart-Allmaras based turbulence models (be it SA-RANS or any of the SA-DES models).
The field "nut" is the actual "turbulent viscosity" and is proportional to "nuTilda" by the fv1 function, where fv1 is locally a function of the viscosity ratio nuTilda/nu.
One should always initialize the field "nuTilda" appropriately.
Kummi and rarnaunot like this.
msuaeronautics is offline   Reply With Quote
Old   April 22, 2016, 05:30
aerospain
aerospain is on a distinguished road
Send a message via Skype™ to aerospain
Dear Albrecht,
A quick question about initializing nut from nuTilda (SA model) in OpenFOAM3.0.1. Should I include a nut file in 0/ directory with values calculated manually from nuTilda? (using fv1 and Cv1) or, will OF generate nut files automatically once the simulation runs?
Usually, to be on the safe side, I would initialize the nut file manually in 0/, but I was just wondering if that may create any conflict with OF as the way of dealing with some algorithms may change between versions.
Thanks!
aerospain is offline   Reply With Quote
Old   November 27, 2018, 03:37
Vidyuth
vidyuth is on a distinguished road
Originally Posted by DLC View Post
hello everyone!
can someone tell me how to initialize nut and nuTilda? I always used kOmegaSST and for those I found the formulas to initialize k and omega, but I couldn't find out how to initialize variables for spalartAlllmaras..
Thank you!
Hi, can you please tell me the formulas for determining epsilon and omega values?
vidyuth is offline   Reply With Quote
Old   June 5, 2020, 08:30
Default Solving for nuTilda graphically
  #30
paul
pichetzh is on a distinguished road
Originally Posted by rafamusura View Post
Robert Ong
I'm not shure that's the way it work, because you are defining nut=fv1*nutilda, fv1=x^3/(x^3 + cv1^3), and like you say X is a function of nut, if so you're defining nut as a function of nut, nut=nutida*f(nut).
in the wiki page http://www.cfd-online.com/Wiki/Spalart-Allmaras_model, X is defined as nutlinda/nu. So what's the rigth interpretation?.
Tobi, I have the same question, I was trying to get a k-e simulation but it always crashed, so I took a step backward to a more simple model first. If you have the answer for that just let me know.
A) How does one solve for nuTilda in the following equation?
nuTilda = nuT/fv1
=nuT*(1+(CV1/chi)^3)
= nuT*(1+(CV1*nu/nuTilda)^3)
This is not easy to solve analytically, but graphically it is trivial:
1. plot y1 = x
2. plot y2 = nuT*(1+(CV1*nu/x)^3)
3. Where y1 intersects y2, say at point P* = (x*, y*), x* is your nuTilda.
B) When can I use the approximation nuTilda ~ nuT?
This approximation requires (CV1*nu/nuTilda)^3 << 1.
As a rule of thumb, let's say we want nuTilda to be within 1% of nuT, ie., nuTilda = 1.01 nuT. Then nu/nuT = 0.01^(1/3)*1.01/CV1 = 3.06%, or taking the reciprocal nuT/nu = 1/0.0306 = 32.6.
That is to say, if your turbulent viscosity is > 33 times dynamic viscosity, go ahead and use nuTilda = nuT.
pichetzh is offline   Reply With Quote
Old   June 12, 2020, 21:13
Claudio Boezio
Ship Designer is on a distinguished road
Originally Posted by tcarrigan View Post
If I understand correctly, If you'd like to initialize and record nut and nuTilda when using kOmegaSST, simply place them in the 0 directory and set them to 0...or you could calculate them based on k and omega.
Because nut and nuTilda aren't required when using kOmegaSST (only k and omega are required), by placing the nut and nuTilda dictionary files in the 0 directory, you're forcing OpenFOAM to record those values at each iteration. This is good for postprocessing as you don't have to calculate them yourself after the simulation is over.
Note: I believe that nut and nuTilda are only required for the SpalartAllmaras turbulence model.
Hope this helps.
Can somebody please confirm that for RASModel kOmegaSST; the nut field is not required? I've just tried that out by renaming the nut file in the 0 directories of a parallel case and interFoam aborts with the error message attached below. Thanks!
File Type: jpg interFoam aborts if nut file not found.jpg (46.7 KB, 25 views)
Ship Designer is offline   Reply With Quote
Old   June 13, 2020, 05:27
JNSN's Avatar
Jan
JNSN is on a distinguished road
Nut is required
Ship Designer likes this.
JNSN is offline   Reply With Quote
Old   June 13, 2020, 09:53
Claudio Boezio
Thanks Jan!
nut nutilda
SpalartAllmaras question egp OpenFOAM Running, Solving & CFD 45 October 28, 2010 04:30
