January 21, 2010, 09:46 |
simpleFoam error
#1 | |||
Rep Power: 17 |
Hi Foamers,
I have a problem with simpleFoam. Every time I try to run the solver, I recieve this error Quote:
This is fvSchemes Quote:
January 21, 2010, 11:06 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi Erik
The error is due to the fact that you have specified 0 as boundary conditions/internal field for k and/or epsilon (errro #3 and #6 tells the story). Your need to specify finite values, however to remember when setting them that they need to be chosen such that the eddy viscosity is not initialized with some large value. Bests, Niels |
January 21, 2010, 11:21 |
Rep Power: 17 |
Hi Niels,
thanks a lot! Now it's running. I've set k=0,375 and epsilon=14.855. Best regards, Erik |
January 25, 2010, 08:41 |
#4 | |||||||||
Rep Power: 17 |
Hi Foamers,
I still have trouble with my simulation. bounding epsilon is exploding and huge right from the start! It's about a pipe flow with a starting pressure of 7638Pa and a inlet velocity of 1.7448 m/s. I'm interessted in the drop of pressure an the end of the curved pipe. Quote:
These are my settings: k Quote:
January 25, 2010, 08:49 |
maddalena
Rep Power: 23 |
I think your problem is connected with the boundary conditions: you are imposing a fixed value for p and U at the inlet and none at the outlet. You should use:
maddalena |
January 25, 2010, 09:18 |
Rep Power: 17 |
I'll try it right now, but I don't understand it realy.
I have a pressure of 7638Pa and a velocity of 1,7448 m/s at the inlet, both values are fixed. How should I enter fixed value for p (or U) at the outlet, although this is what I'm interesseted in? |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 10:31 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 21:50 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 18:38 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 07:31 |
