NACA - Inclined flow / symmetryPlane
Old   January 21, 2010, 03:47
Default NACA - Inclined flow / symmetryPlane
Stefan
SD@TUB is on a distinguished road
Hello folks,
i investigate some elementary hydrodynamics using i.e. NACA profiles. The following illustration shows the case in 2D:
             OUTLET
   _________________________
   |domain                 |
   |                       | s
   |                       | y
   |                      #| m
   |                     ##| m
   |                     ##| e
 S |                    ###| t
 I |                    ###| r
 D |                   ####| y
 E |                   ####| P
   |                   ####| l
   |                   ####| a
   |                   ####| n
   |                   ####| e
   |_______________________|
             INLET
  /    /    /  inclined flow
As you can see, i use a symmetryPlane to split my bounding domain (BTW: '#' represent on half of an airfoil).
My question/problem:
When i want a specified angle fo attack, what is the direction of the flow on the reflected INLET (domain)? I guess the inclined flow is mirrored, too.
Is there a possibility to maintain the inclined flow direction in case of that (e.g. that only the geometry/mesh will be duplicate, not the physical boundaries, maybe the mirrorMesh utility could help)?
thx,
/Stefan
SD@TUB is offline   Reply With Quote
airfoil, inclined flow, naca, symmetryplane
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 12:47
Inclined Open Channel Flow Abe Gonzalez FLUENT 2 April 15, 2008 13:32
reversed flow at velocity inlet / mass flow inlet ib FLUENT 1 March 26, 2007 14:11
How to change from mass flow to volume flow rate stanley FLUENT 1 February 2, 2007 07:44
transform navier-stokes eq. to euler-eq. pxyz Main CFD Forum 37 July 7, 2006 09:42
