Swirl at inlet boundary
Old   November 6, 2017, 10:38
Graham
benham is on a distinguished road
Hi there,
I am having trouble compiling the addSwirlAndRotation feature.
Following:
http://openfoamwiki.net/index.php/Si...irlAndRotation
I have run these lines:
svn checkout svn://svn.code.sf.net/p/openfoam-extend/svn/trunk/Breeder_1.5/OSIG/TurboMachinery/applications applications_SIGturbo
svn checkout svn://svn.code.sf.net/p/openfoam-extend/svn/trunk/Breeder_1.5/OSIG/TurboMachinery/src src_SIGturbo
Now I want to run the folowing lines:
cd $WM_PROJECT_USER_DIR/applications_SIGturbo/utilities/preProcessing/addSwirlAndRotation/
wclean
wmake
rehash #if necessary
This is the output of my code:
Making dependency list for source file addSwirlAndRotation.C
g++ -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -I/home/benham/openfoam/openfoam30/src/finiteVolume/lnInclude -I/home/benham/openfoam/openfoam30/src/turbulenceModels/RAS -I/home/benham/openfoam/openfoam30/src/transportModels -I/home/benham/openfoam/openfoam30/src/meshTools/lnInclude -IlnInclude -I. -I/home/benham/openfoam/openfoam30/src/OpenFOAM/lnInclude -I/home/benham/openfoam/openfoam30/src/OSspecific/POSIX/lnInclude -fPIC -c addSwirlAndRotation.C -o /home/benham/openfoam/openfoam30/platforms/linux64GccDPInt32Opt/applications_SIGturbo/utilities/preProcessing/addSwirlAndRotation/addSwirlAndRotation.o
g++ -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -I/home/benham/openfoam/openfoam30/src/finiteVolume/lnInclude -I/home/benham/openfoam/openfoam30/src/turbulenceModels/RAS -I/home/benham/openfoam/openfoam30/src/transportModels -I/home/benham/openfoam/openfoam30/src/meshTools/lnInclude -IlnInclude -I. -I/home/benham/openfoam/openfoam30/src/OpenFOAM/lnInclude -I/home/benham/openfoam/openfoam30/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed /home/benham/openfoam/openfoam30/platforms/linux64GccDPInt32Opt/applications_SIGturbo/utilities/preProcessing/addSwirlAndRotation/addSwirlAndRotation.o -L/home/benham/openfoam/openfoam30/platforms/linux64GccDPInt32Opt/lib \
-lincompressibleRASModels -lincompressibleTransportModels -lfiniteVolume -lmeshTools -lOpenFOAM -ldl \
-lm -o /home/benham/OpenFOAM/benham-3.0.1/platforms/linux64GccDPInt32Opt/bin/addSwirlAndRotation
/usr/bin/ld: cannot find -lincompressibleRASModels
collect2: error: ld returned 1 exit status
/home/benham/openfoam/openfoam30/wmake/Makefile:138: recipe for target '/home/benham/OpenFOAM/benham-3.0.1/platforms/linux64GccDPInt32Opt/bin/addSwirlAndRotation' failed
make: *** [/home/benham/OpenFOAM/benham-3.0.1/platforms/linux64GccDPInt32Opt/bin/addSwirlAndRotation] Error 1
Could anyone help me out?
Many thanks,
Graham
benham is offline   Reply With Quote
Old   November 7, 2017, 11:03
Graham
Hi there,
I have managed to compile the addSwirlAndRotation utility but when I execute it inside the case studies here:
https://www.openfoamwiki.net/index.p...nical_diffuser
I get the following error:
*** Error in `addSwirlAndRotation': free(): invalid pointer: 0x00007ffc34a514d8 ***
Can anyone help me please?
Best wishes,
Graham
Old   November 13, 2017, 14:18
Christian Schmitz
cschmitz is on a distinguished road
I dont see how the addSwirlAndRotation utility depends on any incompressibleRASModels.
You can probably remove the line that says "-lincompressibleRASModels" from the Make/options file, as well as the line that says "-lincompressibleTransportModels".
cschmitz is offline   Reply With Quote
Old   December 5, 2017, 05:03
Graham
Issue was solved by updating to OF5.0.
Pressure Inlet Boundary Condition Prasad FLUENT 6 April 9, 2013 22:32
Inlet and outlet boundary condition David Baker FLUENT 3 June 22, 2005 01:42
Pressure Inlet Boundary Condition Trinity_psu FLUENT 0 June 1, 2005 15:15
user soubroutine of inlet boundary conditions Charlie Beghein Siemens 2 August 30, 2002 03:03
length scales at inlet for internal flows Anne-Marie Giroux Main CFD Forum 3 July 5, 1999 22:28
