December 23, 2009, 01:49 |
coriolis force in MRFSimpleFoam
任芸
Rep Power: 17 |
hi all,
i want to study the effect of coriolis force in pump by MRFSimpleFoam,when i gedit MRFSimpleFoam.C,it occurred: for (runTime++; !runTime.end(); runTime++) { Info<< "Time = " << runTime.timeName() << nl << endl; # include "readSIMPLEControls.H" p.storePrevIter(); // Pressure-velocity SIMPLE corrector { // Momentum predictor tmp<fvVectorMatrix> UEqn ( fvm::div(phi, U) + turbulence->divDevReff(U) ); mrfZones.addCoriolis(UEqn()); UEqn().relax(); solve(UEqn() == -fvc::grad(p)); p.boundaryField().updateCoeffs(); volScalarField rAU = 1.0/UEqn().A(); U = rAU*UEqn().H(); UEqn.clear(); phi = fvc::interpolate(U, "interpolate(HbyA)") & mesh.Sf(); mrfZones.relativeFlux(phi); adjustPhi(phi, U, p); and here is my problem: if i want to delete the coriolis force from the MRFSimpleFoam,what can i do?only delete the red line above?right? or did i need any other operations?for example,the coriolis force described in MRFZones.C also: void Foam::MRFZone::addCoriolis(fvVectorMatrix& UEqn) const { if (cellZoneID_ == -1) { return; } const labelList& cells = mesh_.cellZones()[cellZoneID_]; const scalarField& V = mesh_.V(); vectorField& Usource = UEqn.source(); const vectorField& U = UEqn.psi(); const vector& Omega = Omega_.value(); forAll(cells, i) { Usource[cells[i]] -= V[cells[i]]*(Omega ^ U[cells[i]]); } } should i delete the code above ? thanks in advance jennifer |
December 23, 2009, 02:40 |
Just remove : mrfZones.addCoriolis(UEqn()); but i don`t think it is a topic for study |
October 28, 2013, 07:27 |
Dear Renyun0511 and Wayne,
I am working on axial flow fan, I want to see the effect of Coriolis force in the fan. I am using MRFSimpleFoam, how can I switch of Coriolis force effect. Do I need to write a new solver or can I command out some of the line in the existing code? Please help me in this regard.... Thanks, Sivakumar |
Urgently Need the code of Lift force and VM force | Kai Yan | Main CFD Forum | 0 | July 16, 2008 07:07 |
DEFINE_CG_MOTION and pressure force | Teo Fumagalli | FLUENT | 0 | April 11, 2008 10:25 |
MRFZonesC questions what is the mesh_V and why only Coriolis force no centrifugal force | waynezw0618 | OpenFOAM Running, Solving & CFD | 49 | April 8, 2008 04:23 |
pressure force and viscous force | CFD | FLUENT | 0 | March 7, 2006 01:03 |
Coriolis force | Saturn | FLUENT | 5 | September 30, 2004 15:56 |
