Problem running IDDES with pimpleFoam
Old   December 21, 2009, 09:28
Default Problem running IDDES with pimpleFoam
Charles Mockett
charlie is on a distinguished road
Dear OpenFOAM users,
I am trying to test the new SpalartAllmarasIDDES implementation in OpenFOAM 1.6. I am using pimpleFoam to test its capabilities to exceed a Courant number of 1.
I believe I have set up everything correctly, however when I run my case the following error is output. I don't understand why it wants details of a RAS model, since I specified an LES model. I'm not sure if this is a bug or an error in my usage. I would be very grateful for any help!
Best regards,
Charlie.
Error output:
Selecting incompressible transport model Newtonian
Selecting turbulence model type LESModel
Selecting LES turbulence model SpalartAllmarasIDDES
request for RASModel RASProperties from objectRegistry region0 failed
available objects of type RASModel are
0
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/mockett/CFD/Solvers/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/mockett/CFD/Solvers/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Foam::Ostream& Foam:perator<< <Foam::error>(Foam::Ostream&, Foam::errorManip<Foam::error>) in "/home/mockett/CFD/Solvers/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/pimpleFoam"
#3 Foam::incompressible::RASModel const& Foam:bjectRegistry::lookupObject<Foam::incompres sible::RASModel>(Foam::word const&) const in "/home/mockett/CFD/Solvers/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libincompressibleRASModels.so"
#4 Foam::incompressible::RASModels::nutWallFunctionFv PatchScalarField::calcNut() const in "/home/mockett/CFD/Solvers/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libincompressibleRASModels.so"
#5 Foam::incompressible::RASModels::nutWallFunctionFv PatchScalarField::updateCoeffs() in "/home/mockett/CFD/Solvers/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libincompressibleRASModels.so"
#6 Foam::fvPatchField<double>::evaluate(Foam::Pstream ::commsTypes) in "/home/mockett/CFD/Solvers/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/pimpleFoam"
#7 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::evaluate() in "/home/mockett/CFD/Solvers/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/pimpleFoam"
#8 Foam::incompressible::LESModels::SpalartAllmaras:: updateSubGridScaleFields() in "/home/mockett/CFD/Solvers/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libincompressibleLESModels.so"
#9 Foam::incompressible::LESModels::SpalartAllmaras:: SpalartAllmaras(Foam::GeometricField<Foam::Vector< double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&) in "/home/mockett/CFD/Solvers/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libincompressibleLESModels.so"
#10 Foam::incompressible::LESModels::SpalartAllmarasID DES::SpalartAllmarasIDDES(Foam::GeometricField<Foa m::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&) in "/home/mockett/CFD/Solvers/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libincompressibleLESModels.so"
#11 Foam::incompressible::LESModel::adddictionaryConst ructorToTable<Foam::incompressible::LESModels::Spa lartAllmarasIDDES>::New(Foam::GeometricField<Foam: :Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&) in "/home/mockett/CFD/Solvers/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libincompressibleLESModels.so"
#12 Foam::incompressible::LESModel::New(Foam::Geometri cField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&) in "/home/mockett/CFD/Solvers/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libincompressibleLESModels.so"
#13 Foam::incompressible::turbulenceModel::addturbulen ceModelConstructorToTable<Foam::incompressible::LE SModel>::NewturbulenceModel(Foam::GeometricField<F oam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&) in "/home/mockett/CFD/Solvers/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libincompressibleLESModels.so"
#14 Foam::incompressible::turbulenceModel::New(Foam::G eometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&) in "/home/mockett/CFD/Solvers/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libincompressibleTurbulenceModel.so"
#15 main in "/home/mockett/CFD/Solvers/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/pimpleFoam"
#16 __libc_start_main in "/lib/tls/libc.so.6"
#17 _start at ../sysdeps/i386/elf/start.S:122
From function objectRegistry::lookupObject<Type>(const word&) const
in file /home/dm2/henry/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 140.
FOAM aborting
Aborted
charlie is offline   Reply With Quote
Old   December 22, 2009, 12:14
Fabian Braennstroem
braennstroem is on a distinguished road
Hi Charlie,
one chance is, that you used the wrong wall treatment in nuTilda!? It has to be something like nuSgs...WallTreatment.
Best Regards!
Fabian
braennstroem is offline   Reply With Quote
Old   December 22, 2009, 18:35
Charles Mockett
Hi Fabian,
Thanks very much - that seems to have solved the problem!
Merry Christmas,
Charlie.
Old   March 10, 2010, 10:00
Default Problem running LRRDiffStress
Ana Maria Aramayo
gmc_unsa is on a distinguished road
Dear Fabian,
We are trying to test LRRDiffStress implementation in OpenFOAM 1.6 with LESModel. We are using buoyantPisoFoam for a cavity.
When we run our case the following error is output. We don't understand the error message.
We don't know if our boundary condition for B, nutilda or nusgs, are correct?
We would be very grateful for any help!
Ana and Sonia
Reading g
Reading thermophysical properties
Reading field T
Reading field p
Reading field U
Selecting LES turbulence model LRRDiffStress
LRRDiffStressCoeffs
ce 1.048;
couplingFactor 0;
ck 0.09;
c1 1.8;
c2 0.6;
Courant Number mean: 0 max: 0
Starting time loop
Time = 0.001
DILUPBiCG: Solving for Ux, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 1.35638e-08, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG: Solving for T, Initial residual = 1, Final residual = 1.35807e-07, No Iterations 1
DICPCG: Solving for p, Initial residual = 1, Final residual = 0.363883, No Iterations 7
time step continuity errors : sum local = 3.56917e-05, global = -7.6233e-22, cumulative = -7.6233e-22
DICPCG: Solving for p, Initial residual = 0.155533, Final residual = 0.155533, No Iterations 0
time step continuity errors : sum local = 3.57045e-05, global = 1.23879e-21, cumulative = 4.76456e-22
DICPCG: Solving for p, Initial residual = 0.155533, Final residual = 8.23312e-07, No Iterations 71
time step continuity errors : sum local = 1.89001e-10, global = 1.71523e-21, cumulative = 2.19168e-21
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/foam6/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/foam6/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 ?? in "/lib64/libc.so.6"
#3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/home/foam6/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#4 void Foam::divide<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/home/foam6/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so"
#5 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/home/foam6/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libincompressibleLESModels.so"
#6 Foam::incompressible::LESModels::LRRDiffStress::co rrect(Foam::tmp<Foam::GeometricField<Foam::Tensor< double>, Foam::fvPatchField, Foam::volMesh> > const&) in "/home/foam6/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libincompressibleLESModels.so"
#7 Foam::incompressible::LESModel::correct() in "/home/foam6/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libincompressibleLESModels.so"
#8 main in "/home/foam6/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/flotacionLESFoam"
#9 __libc_start_main in "/lib64/libc.so.6"
#10 Foam::regIOobject::writeObject(Foam::IOstream::str eamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/home/foam6/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/flotacionLESFoam"
Floating point exception
gmc_unsa is offline   Reply With Quote
Old   March 11, 2010, 15:57
Fabian Braennstroem
I do not know this model, but I assume, that you have an initial field for B, which is set to 0...
Fabian
Old   March 17, 2010, 09:57
Ana Maria Aramayo
Dear Fabian
Sorry by our tardy answering, respect to B field it was have actually initialized on 0, we changed for to small value but the problem continued. We found that the problem was boundary condition, too. It changed it to small value and worked fine.
Thank for you help
Ana and Sonia
Old   April 30, 2013, 06:05
Sha Huang
Joanna Huang is on a distinguished road
Originally Posted by charlie View Post
Hi Fabian,
Merry Christmas,
Charlie.
Hi Charlie,
Can I ask how you sovle the problem. Since it doesn't work for me. I have tried may ways, still have the error, could you pleas kindly to tell me how to set the IDDES simulation. Thank you so much.
Best regards,
Joanna
Joanna Huang is offline   Reply With Quote
Old   July 11, 2013, 12:45
菊爆大队总队长 is on a distinguished road
Originally Posted by Joanna Huang View Post
Hi Charlie,
Best regards,
Joanna
Hi I have the same problem with SA DDES simulation. Could you tell me how you solved it?
菊爆大队总队长 is offline   Reply With Quote
Problem with running rsh on Windows sever 2008 mr_aliagha Main CFD Forum 0 September 17, 2009 06:33
the problem of running star-cd after pro-star liu-jinsong Siemens 0 November 20, 2008 21:58
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 08:52
Problem in running CFX in red hat linux Q CFX 0 March 30, 2006 10:11
problem running parallel-help needed Shankar FLUENT 0 December 16, 2002 14:45
