GAMG does not work using the regionCouple-BC
Old   December 17, 2009, 05:50
Default GAMG does not work using the regionCouple-BC
Stefan Herbert
herbert is on a distinguished road
Hi all,
I'm using OpenFOAM 1.5-dev in order to calculate conjugate heat transfer. This works fine, but when I want to solve the p-Equation in one region only using GAMG I get the following massage:
Unknown GAMGInterface type regionCouple.
Valid GAMGInterface types are :
4
cyclicGgi
ggi
cyclic
processor
When using any other solver (e.g. PCG) everything works fine.
Has someone a hint for me?
Regards
Herbert
herbert is offline   Reply With Quote
Old   December 17, 2009, 11:01
Stefan Herbert
Me again,
I'm not sure if it was possible to change the boundaryType while the solver is running. This should solve the problem, but I don't know how to implement.
regioncouple 1.5-dev
Error log vw.cfd OpenFOAM 6 August 7, 2009 06:44
Errno 24 linux ivanwhlau OpenFOAM Running, Solving & CFD 6 July 1, 2009 11:16
MRFSimpleFoam amp cyclic patches david OpenFOAM Running, Solving & CFD 36 October 21, 2008 22:55
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 12:16
SonicTurbFoam crashes when turbulence is added gastovski OpenFOAM Running, Solving & CFD 0 January 21, 2008 08:49
