Rewriting twoPhaseEulerFoam in conservative form |
November 2, 2011, 12:47 |
#21 |
Kent Wardle
Rep Power: 21 |
Eric,
This has been somewhat fixed--as part of his work with me on a related solver, Henry has implemented a multiphase version of his MULES solver which improves the phase fraction bounding for the multiphase case by several orders of magnitude. I imagine this will be out in future versions of the code. -Kent |
November 2, 2011, 13:05 |
#22 |
Alberto Passalacqua
Rep Power: 36 |
Interesting. Why do you need MULES in a multi-fluid solver, since MULES is typically used to track free surfaces?
Limiting alpha is done in most of the multi-fluid codes with re-normalization of the variable, and enforcement of the mass conservation principle. You can refer to the implementation of codes for nuclear applications like NEPTUNE CFD, or to other multiphase codes like MFIX. Essentially, the idea (from NEPTUNE paper) is to solve for the phase fraction of all the phases, solve for the pressure equation based on total continuity and repeat until 1 - sum(alpha) < epsilon, being epsilon a very small number. In this process some Author re-normalize alpha so that alpha = alpha/sum(alpha) < 1. It is a pretty standard approach, but it is also robust. Best,
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
November 2, 2011, 13:13 |
#23 |
Kent Wardle
Rep Power: 21 |
If I was not mistaken Eric's question was about multiphaseInterFoam. As for me, I am indeed trying to track free surfaces within the context of a multi-fluid solver which is why it is needed/used.
November 2, 2011, 13:18 |
#24 |
Alberto Passalacqua
Rep Power: 36 |
My bad, sorry. I was misled by the title of the thread!
November 2, 2011, 13:23 |
#25 |
Alberto Passalacqua
Rep Power: 36 |
@Kent Did you get the reply to your email?
May 13, 2015, 10:40 |
#26 |
Freedom
Rep Power: 13 |
Dear Alberto,
Now I am interested in QMOM and want to do research on this. I find that you have an openSource called OpenQBMM in gitHub. But I could not download it. Could you be so kind send it to me? My email: 981588592@qq.com Regards, Xu |
May 26, 2015, 03:05 |
#27 | |
Vishal
Rep Power: 13 |
Dear Alberto, I am working on same solver (twoPhaseEulerFoam) for bubble column. I am Simulating Hills case (1974) for cylindrical bubble column. I am describing my case in detail here. I am running simulations where gas is sparged in the liquid column at superficial velocity of 64 mm/s at the inlet. When the gas rises throughout the column we have some gas hold up and slip velocity for bubbles or actual gas rise velocity at all the axial point in the column. If there is no mass transfer from gas to liquid, that is, no gas dissolved in the liquid, in order to have mass conservation of gas at any axial position in the column, superficial gas velocity (and hence the mass flux of gas) should be same throughout the column and must be equal to 64 mm/s. In other words, (local gas holdup * local bubble rise velocity) must be equal to that of the superficial gas velocity with which gas is entering the column. In order to observe this, I have plotted superficial gas velocity along the axial position in the column as shown in attachment. I have observed that, near inlet (for axial position (Z)<0.1) there is substantial reduction in the superficial velocity of gas, which is an indication of loss of mass for gas in that region. but as we start moving away from the inlet, it is observed that the superficial velocity of gas increases (or recovery of mass of gas) and finally reached the 64 mm/s at Z=0.7 and remains there. I tried to understand this behavior of gas in the column n meanwhile came across this post of yours. I wonder if that is the reason why I have loss of gas near inlet or is there any other reason??. What could be the other possibility? Please help me to get though this. Thanking you... |
October 12, 2015, 05:32 |
BubbleFoam limitations
#28 |
Rep Power: 10 |
I want to use bubblefoam solver but it prevents on my work, because of bubblefoam limitations.
BubbleFoam limitations The diameter of the particles constituting the dispersed phase is assumed to be consistent. Aggregation, breakage and coalescence phenomena are not accounted for. What is your suggestion? DO you know any solver uses Euler mixture model ? thank you |
October 15, 2015, 05:18 |
#29 |
Meng Liu
Rep Power: 11 |
Hi, Alberto.
Recently, I try to use DQMOM method in Fluent to simulate a two-phase flow (water and gas). Because DQMOM method requires three second phases, I set three gas phases. Is this right ? Besides,I don't know how to set the m4 and vof value of three second phases in boundary condition. Best regards. |
October 15, 2015, 13:28 |
#30 |
Rep Power: 10 |
October 20, 2015, 00:30 |
#31 |
Vishal
Rep Power: 13 |
Hi Masoudsh
Which openfoam version are you using? I think bubbleFoam solver is disconinued (though I am not sure) after OF170. look into twoPhaseEulerFoam solver in the recent version of OF (OF231/OF240). Hope it might work for you. All the best |
October 27, 2015, 17:06 |
#32 |
Rep Power: 10 |
Hi vishal
thank you from your suggestion. how is multiphaseEulerFoam? Best regard |
October 27, 2015, 22:30 |
#33 |
Vishal
Rep Power: 13 |
Hi masoudsh
Multiphaseeulerfoam can also do your job. But being specific about the solver, it is used when your system has more than two phases in it, for example gas-liquid-solid. Whereas twophaseeulerfoam is used only for two phase systems. With kind regards |
November 7, 2015, 21:33 |
#34 |
Andrew Eisenhawer
Rep Power: 13 |
masoudsh,
I am no expert in this area, but have you considered the IATE diameter model in twoPhaseEulerFoam (i.e., recent OF, not Foam-ext)? If you don't need to resolve individual tiny bubbles, but want to keep track of bubble surface area, for example, it is an elegant solution. IATE accounts for bubble breakage, coalescence due to wake, etc. At the other end of the scale, interFoam (incompressible) is useful for looking at individual bubbles if incompressibility isn't an issue (small pressure/depth gradient), but the grid must be much smaller than the smallest bubble. Last edited by aee; November 8, 2015 at 02:19. |
November 8, 2015, 08:22 |
#35 |
Rep Power: 10 |
hello
what is IATE? is it in twoPhaseEulerFoam? thank you for reply to my question |
November 8, 2015, 13:15 |
#36 |
Andrew Eisenhawer
Rep Power: 13 |
IATE is "interfacial area transport equation"
Yes, it is available in twoPhaseEulerFoam. See tutorials > multiphase > twoPhaseEulerFoam > laminar > bubbleColumnIATE and study the constant > phaseProperties file. IATE will also require the kappa.* and Theta.* files in the 0 folder, and a few other considerations (e.g., thermophysicals) depending on the model assumptions. So far, it seems to be fairly realistic for air/water. Last edited by aee; November 8, 2015 at 20:01. |
May 27, 2016, 09:06 |
#37 |
Rep Power: 10 |
thank you for reply
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 05:45 |
conservative, non conservative form???? | vijesh joshi | Main CFD Forum | 5 | April 21, 2022 06:37 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
Equations in full form | Mark Render | Main CFD Forum | 3 | June 20, 2000 15:05 |
