Strange behaviour on outlet boundary using LES
Old   December 9, 2009, 04:57
Default Strange behaviour on outlet boundary using LES
David Segersson
segersson is on a distinguished road
I get a nasty inflow on the outlet boundary when doing LES using buoyantBoussinesqPisoFoam in OF 1.6.x (changed to allow generic turbulence models the same way as pisoFoam). The inflow seems to be caused by a very low pressure in the cells closest to the outlet boundary in the south-east corner of the domain.
I'm running a test case for a heavy plume from a chimney surrounded by a number of buildings. I have tried three different meshes with different resolution at the outlet. I tried one mesh with very low resolution of perfect hex cells just before the outlet in order to get a diffuse very "nice" outflow.
I have tried different numerical shemes (linear, upwind, limitedLinear). However, the soultion does not blow up. I've kept the courant number below one (approx. 0.5). I am currently trying to use Smagorinsky but have also tried with oneEqEddy.
The bc:s are:
east (outlet) : U inletOutlet, p fixedValue, nuSgs zeroGradient
west(inlet) : U fixedValue, p zeroGradient, nuSgs zeroGradient
north: slip
south:slip
top:slip
ground:wall function
chimney: wall function
building: wall functions
The case is initialized using a converged run with simpleFoam. So far the temperature field is uniform, which should make the solver very similar to pisoFoam.
I have run out of ideas! Has anyone seen a similar behaviour? I have very limited experience of LES, so please tell me if you see something that seems strange in my setup.
Regards
David
segersson is offline   Reply With Quote
les, outlet boundary, pressure bc
outlet boundary condition for compressor modeling siamak1424 FLUENT 3 August 8, 2009 06:55
VOF Outlet boundary condition in cfd - ace JM Main CFD Forum 0 December 15, 2006 09:07
Solver error message!!! IoSa CFX 1 September 14, 2006 05:48
Outlet boundary condition CN FLUENT 6 May 22, 2005 10:37
Inlet and Outlet Boundary conditions for LES Jan Ramboer Main CFD Forum 12 August 6, 1999 23:00
