Problems with Turbulence Modeling
Old   November 26, 2009, 05:48
Default Problems with Turbulence Modeling
Jignesh
ezsoal is on a distinguished road
I need to simulate flow over a cylinder for the following cases:
1) Inviscid Flow
2) Viscous Subsonic
3) Viscous Subsonic with RAS Turbulence
4) Supersonic
I'm able to simulate the first two (using potentialFoam and icoFoam respectively), but am getting this error while trying to simulate the last two (using pisoFoam and sonicFoam respectiely)
Create time
Create mesh for time = 0
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type RASModel
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
Cmu 0.09;
C1 1.44;
C2 1.92;
sigmaEps 1.3;
Starting time loop
Time = 0.0005
Courant Number mean: 0.000271663 max: 0.00134942
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 5.73156e-08, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 6.21305e-08, No Iterations 1
DICPCG: Solving for p, Initial residual = 1, Final residual = 0.0913066, No Iterations 31
time step continuity errors : sum local = 8.14153e-05, global = -4.30474e-06, cumulative = -4.30474e-06
DICPCG: Solving for p, Initial residual = 0.0302236, Final residual = 6.3797e-07, No Iterations 49
time step continuity errors : sum local = 7.42487e-08, global = 1.87645e-10, cumulative = -4.30455e-06
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/jignesh/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/jignesh/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted:
#3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/home/jignesh/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#4 void Foam::divide<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/home/jignesh/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libincompressibleRASModels.so"
#5 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/home/jignesh/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libincompressibleRASModels.so"
#6 Foam::incompressible::RASModels::kEpsilon::correct () in "/home/jignesh/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libincompressibleRASModels.so"
#7 main in "/home/jignesh/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/pisoFoam"
#8 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
#9 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/i386/elf/start.S:122
Floating point exception
Note that the geometry remains the same in all the cases, only the solver and the relevant inputs and boundary types change depending upon the case.
Also, for the supersonic case, the solution blows up (as shown above) after several iteration, whereas for the subsonic turbulent case, it blows up right from the start.
Can anyone please gimme a clue as to what is it that I'm doing wrong?
Regards,
Jignesh
ezsoal is offline   Reply With Quote
Old   November 26, 2009, 08:49
Ulrich Heck
ulli is on a distinguished road
Hi Jignesh,
I think there is something wrong with your initial turbulence conditions. This might be caused by your turbulence div-schemes. Waht do you use?
Ulrich
ulli is offline   Reply With Quote
Old   November 26, 2009, 09:44
Jignesh
Hi Ulrich,
thanks for responding.
I dont have much of a background in CFD. Basically, I've jst copied all the initial data files in the '0' directly (p, U, k, epsilon, nut, nutilda, epsilon) from a similar tutorial and modified them to reflect the patches in my geometry. ( this worked for the previous cases - potentialFoam and icoFoam)
Also, I've simply copied the fvSolution and fvSchemes files from that sample tutorial which solves a flow with RAS Turbulence.
I'm reproducing the contents of these files. I would really appreciate if you could have a look and suggest a way out.
Anticipating response,
Regards,
Jignesh
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
down
type symmetryPlane;
cylinder
type symmetryPlane;
frontAndBack
type empty;
fixedWall
type zeroGradient;
left
type zeroGradient;
right
type fixedValue;
value uniform 0;
FoamFile
version 2.0;
format ascii;
class volVectorField;
location "0";
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
down
type symmetryPlane;
cylinder
type symmetryPlane;
frontAndBack
type empty;
fixedWall
type fixedValue;
value uniform (0 0 0);
left
type fixedValue;
value uniform (5 0 0);
right
type zeroGradient;
FoamFile
version 2.0;
format ascii;
location "0";
object k;
internalField uniform 0.00325;
boundaryField
down
type symmetryPlane;
cylinder
type symmetryPlane;
frontAndBack
type empty;
fixedWall
type kqRWallFunction;
value uniform 0.00325;
left
type zeroGradient;
right
type fixedValue;
value uniform 0;
FoamFile
version 2.0;
format ascii;
class volSymmTensorField;
object R;
internalField uniform (0 0 0 0 0 0);
boundaryField
down
type symmetryPlane;
cylinder
type symmetryPlane;
frontAndBack
type empty;
fixedWall
left
type fixedValue;
value uniform (0 0 0 0 0 0);
right
type zeroGradient;
FoamFile
version 2.0;
format ascii;
location "0";
object epsilon;
dimensions [0 2 -3 0 0 0 0];
internalField uniform 0.000765;
boundaryField
down
type symmetryPlane;
cylinder
type symmetryPlane;
frontAndBack
type empty;
fixedWall
type epsilonWallFunction;
Cmu 0.09;
kappa 0.41;
E 9.8;
value uniform 0.000765;
right
type zeroGradient;
left
type fixedValue;
value uniform 14.855;
FoamFile
version 2.0;
format ascii;
location "0";
object nut;
dimensions [0 2 -1 0 0 0 0];
boundaryField
down
type symmetryPlane;
cylinder
type symmetryPlane;
frontAndBack
type empty;
fixedWall
type nutWallFunction;
Cmu 0.09;
kappa 0.41;
E 9.8;
value uniform 0;
left
type calculated;
value uniform 0;
right
type calculated;
value uniform 0;
FoamFile
version 2.0;
format ascii;
object nuTilda;
boundaryField
down
type symmetryPlane;
cylinder
type symmetryPlane;
frontAndBack
type empty;
fixedWall
left
type fixedValue;
value uniform 0;
right
type zeroGradient;
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSchemes;
ddtSchemes
default Euler;
gradSchemes
default Gauss linear;
grad(p) Gauss linear;
grad(U) Gauss linear;
divSchemes
default none;
div(phi,U) Gauss limitedLinearV 1;
div(phi,k) Gauss limitedLinear 1;
div(phi,epsilon) Gauss limitedLinear 1;
div(phi,R) Gauss limitedLinear 1;
div(R) Gauss linear;
div(phi,nuTilda) Gauss limitedLinear 1;
div((nuEff*dev(grad(U).T()))) Gauss linear;
laplacianSchemes
default none;
laplacian(nuEff,U) Gauss linear corrected;
laplacian((1|A(U)),p) Gauss linear corrected;
laplacian(DkEff,k) Gauss linear corrected;
laplacian(DepsilonEff,epsilon) Gauss linear corrected;
laplacian(DREff,R) Gauss linear corrected;
laplacian(DnuTildaEff,nuTilda) Gauss linear corrected;
interpolationSchemes
default linear;
interpolate(U) linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p ;
Old   November 26, 2009, 10:46
Ulrich Heck
Hi Jignesh
I think you should not force k to zero at your patch "right". Maybe you should try zero gradient instead.
If this doesn't help. Consider more stable schemes for turbulence, e.g.
div(phi,k) Gauss upwind;
div(phi,epsilon) Gauss upwind;
and switch to more accurate schemes later.
But in most cases, when the solution crashes so soon, there is something wrong with the initial conditions or bcs. You can also set turbulence Intensities and mixingLenght for inlets
e.g. k:
type turbulentIntensityKineticEnergyInlet;
intensity 0.01;
value $internalField;
e.g. omega:
type turbulentMixingLengthFrequencyInlet;
mixingLength 0.04;
k k;
For epsilon is turbulentMixingLengthDissipationInlet I think.
Hope this helps
Ulli
Old   November 26, 2009, 16:12
Jignesh
Hey Ulrich,
Thanks for the suggestion; it worked! i got the simulation running flawlessly by NOT forcing k to be equal to zero! now I jst need to ensure that the results that I have are indeed correct...
however, the problem with the supersonic case seems to be something different, since it is blowing up suddenly after 0.0027secs:
Time = 0.00273952
Courant Number mean: 0.00110348 max: 0.0129647
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG: Solving for Ux, Initial residual = 0.970821, Final residual = 4.52189e-06, No Iterations 27
DILUPBiCG: Solving for Uy, Initial residual = 0.950914, Final residual = 8.50896e-06, No Iterations 26
DILUPBiCG: Solving for e, Initial residual = 0.956971, Final residual = 5.481e-06, No Iterations 27
DILUPBiCG: Solving for p, Initial residual = 0.100512, Final residual = 7.64695e-09, No Iterations 13
DILUPBiCG: Solving for p, Initial residual = 0.0364326, Final residual = 9.77965e-09, No Iterations 7
DILUPBiCG: Solving for p, Initial residual = 0.00127526, Final residual = 2.52387e-09, No Iterations 9
time step continuity errors : sum local = 2.60677e-09, global = 1.43791e-09, cumulative = 2.09749e-08
DILUPBiCG: Solving for p, Initial residual = 0.0276749, Final residual = 2.05278e-10, No Iterations 15
DILUPBiCG: Solving for p, Initial residual = 0.019402, Final residual = 1.06515e-09, No Iterations 7
DILUPBiCG: Solving for p, Initial residual = 0.00143388, Final residual = 7.04595e-09, No Iterations 5
time step continuity errors : sum local = 8.05887e-08, global = -4.09812e-08, cumulative = -2.00063e-08
DILUPBiCG: Solving for epsilon, Initial residual = 0.415028, Final residual = 6.03136e-09, No Iterations 35
bounding epsilon, min: -4.23037e+26 max: 6.89055e+26 average: 2.43139e+23
DILUPBiCG: Solving for k, Initial residual = 0.980292, Final residual = 2.48219e-09, No Iterations 34
bounding k, min: -3.11137e+16 max: 2.40184e+17 average: 7.80979e+15
ExecutionTime = 6421.04 s ClockTime = 6739 s
Time = 0.00273956
Courant Number mean: 0.108861 max: 259.099
DILUPBiCG: Solving for Ux, Initial residual = 0.949675, Final residual = 8.48593e-06, No Iterations 26
DILUPBiCG: Solving for Uy, Initial residual = 0.902717, Final residual = 8.30647e-06, No Iterations 26
DILUPBiCG: Solving for e, Initial residual = 0.954222, Final residual = 6.66186e-06, No Iterations 26
Maximum number of iterations exceeded#0 Foam::error:rintStack(Foam::Ostream&) in "/home/jignesh/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/jignesh/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Foam::ePsiThermo<Foam:ureMixture<Foam::constTran sport<Foam::specieThermo<Foam::eConstThermo<Foam:: perfectGas> > > > >::calculate() in "/home/jignesh/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libbasicThermophysicalModels.so"
#3 Foam::ePsiThermo<Foam:ureMixture<Foam::constTran sport<Foam::specieThermo<Foam::eConstThermo<Foam:: perfectGas> > > > >::correct() in "/home/jignesh/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libbasicThermophysicalModels.so"
#4 main in "/home/jignesh/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/sonicFoam"
#5 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
#6 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/i386/elf/start.S:122
From function specieThermo<thermo>::T(scalar f, scalar T0, scalar (specieThermo<thermo>::*F)(const scalar) const, scalar (specieThermo<thermo>::*dFdT)(const scalar) const) const
in file /home/dm2/henry/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/specie/lnInclude/specieThermoI.H at line 68.
FOAM aborting
Aborted
The Courant No is SUDDENLY shooting up by a factor of 20,000 in jst one iteration. Infact the results till t=0.0027 seem to be fairly decent when viewed in paraFoam. but I want to run the simulation till 0.01 to ensure it has reached steady-state; and I have no clue as to WHAT is causing this blowup. Any ideas about trouble shooting? Has it got anything to do with the thermophysical model?
i'm reproducing the files for the supersonic case to make things more clear:
Again, many thanks for the help!
Regards,
Jignesh
FoamFile
version 2.0;
format ascii;
object p;
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 100000;
boundaryField
inlet
type fixedValue;
value uniform 100000;
outlet
type waveTransmissive;
field p;
phi phi;
rho rho;
psi psi;
gamma 1.3;
fieldInf 100000;
lInf 1;
topwall
type zeroGradient;
symplane
type symmetryPlane;
cylinder
type zeroGradient;
frontAndBack
type empty;
FoamFile
version 2.0;
format ascii;
location "0";
object U;
internalField uniform (650 0 0);
boundaryField
topwall
type supersonicFreestream;
pInf 100000;
TInf 300;
UInf (650 0 0);
gamma 1.28418;
value uniform (650 0 0);
symplane
type symmetryPlane;
frontAndBack
type empty;
cylinder
type fixedValue;
inlet
type fixedValue;
outlet
type inletOutlet;
inletValue uniform (0 0 0);
FoamFile
version 2.0;
format ascii;
location "0";
object T;
dimensions [0 0 0 1 0 0 0];
internalField uniform 300;
boundaryField
inlet
type fixedValue;
value uniform 300;
outlet
type inletOutlet;
inletValue uniform 300;
value uniform 300;
symplane
type symmetryPlane;
topwall
type inletOutlet;
value uniform 300;
cylinder
type zeroGradient;
frontAndBack
type empty;
FoamFile
version 2.0;
format ascii;
location "0";
object k;
internalField uniform 1000;
boundaryField
inlet
type fixedValue;
value uniform 1000;
outlet
type inletOutlet;
inletValue uniform 1000;
value uniform 1000;
topwall
type inletOutlet;
value uniform 1000;
symplane
type symmetryPlane;
cylinder
type compressible::kqRWallFunction;
value uniform 1000;
frontAndBack
type empty;
FoamFile
version 2.0;
format ascii;
location "0";
object mut;
dimensions [1 -1 -1 0 0 0 0];
boundaryField
inlet
type calculated;
value uniform 0;
outlet
type calculated;
value uniform 0;
topwall
type calculated;
value uniform 0;
symplane
type symmetryPlane;
cylinder
type mutWallFunction;
Cmu 0.09;
kappa 0.41;
E 9.8;
value uniform 0;
frontAndBack
type empty;
FoamFile
version 2.0;
format ascii;
location "0";
object epsilon;
internalField uniform 25000;
boundaryField
inlet
type fixedValue;
value uniform 25000;
outlet
type inletOutlet;
inletValue uniform 25000;
topwall
type inletOutlet;
symplane
type symmetryPlane;
cylinder
type compressible::epsilonWallFunction;
Cmu 0.09;
kappa 0.41;
E 9.8;
frontAndBack
type empty;
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSchemes;
ddtSchemes
default Euler;
gradSchemes
divSchemes
default none;
div(phi,R) Gauss upwind;
div(phid,p) Gauss limitedLinear 1;
div(phiU,p) Gauss limitedLinear 1;
div(phi,e) Gauss limitedLinear 1;
div((muEff*dev2(grad(U).T()))) Gauss linear;
laplacianSchemes
default none;
laplacian(muEff,U) Gauss linear corrected;
laplacian((rho*(1|A(U))),p) Gauss linear corrected;
laplacian(alphaEff,e) Gauss linear corrected;
default linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p;
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 10:52
Y plus problems with 3D modeling Míša Milakovová FLUENT 0 April 1, 2008 13:09
turbulence modeling error at a stagnation point erdem Fidelity CFD 2 August 15, 2006 16:40
steady turbulence modeling kerem Main CFD Forum 0 April 24, 2006 18:04
CFD - Trends and Perspectives Jonas Larsson Main CFD Forum 16 August 7, 1998 17:27
