November 25, 2009, 10:50 |
initial conditions
stephane sanchi
Rep Power: 18 |
Inside the /0 directory I have the initialConditions file with -------------------------- sideslip 20; velocityMagnitude 20; pressure 0; turbulentKE 0.24; turbulentOmega 1.78; #inputMode merge -------------------------- I have the U file with : -------------------------- #include "initialConditions" dimensions [0 1 -1 0 0 0 0]; internalField uniform ($velocityMagnitude*cos(sideslip) $velocityMagnitude*sin(sideslip) 0); -------------------------- The last line (internalField uniform ...) is not valid. Is it possible to write such an expression there ? Regards, Stephane |
November 26, 2009, 02:25 |
#2 | |
Mark Olesen
Rep Power: 40 |
If you don't mind having two passes, you could write an "initialConditions.m4" and pass it through the m4 processor first to produce your "initialConditions" file. If you look through the tutorials, you can see a few examples where m4+perl has been used to create blockMeshDict files. Here's a quick way to find those examples: Code:
git ls-files | grep .m4 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
Computational time | sunnysun | OpenFOAM Running, Solving & CFD | 5 | March 16, 2009 03:32 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 11:16 |
Unknown error | sivakumar | OpenFOAM Pre-Processing | 9 | September 9, 2008 12:53 |
