November 12, 2009, 19:15 |
Gas leaking along walls and boundary layers?
Rep Power: 17 |
Dear foamers,
I have a pipe case where water enters in one end, goes through a siphon, and exits through a diffuser at a lower z. Air enters through 6 small holes just above the diffuser, and I'm using compressibleInterFoam to solve this problem. But my problem, to be described, exists in the regular interFoam solver too. It seams like the gas entering somehow manages to leak upwards, dispite the current flow of water of 4m/s. The air accumulates further up in the siphon and is not transported away, which is odd. The air enters at 2m/s through 3mm holes. Are there any wall functions I should use, or is this problem related to the meshing (which I have described in another thread recently: http://www.cfd-online.com/Forums/ope...tml#post236057) Also, the gas seem to move from the center of the pipe, and up. The air enters in the middle of the pipe - where it is almost possible to read "air1", "air2" up to "air6"... Please see attached image of volume plot of alpha. |
inlet velocity boundary condition | murali | CFX | 5 | August 3, 2012 09:56 |
Pipe Boundary Layers | Kieran Hood | Main CFD Forum | 0 | April 22, 2007 18:48 |
Boundary layers problem | carlos ortiz | FLUENT | 0 | September 20, 2004 21:55 |
New topic on same subject - Flow around race car | Tudor Miron | CFX | 15 | April 2, 2004 07:18 |
Please help with flow around car modelling! | Tudor Miron | CFX | 17 | March 19, 2004 20:23 |
