swirling flow in simpleFoam compared with FLUENT
Old   November 2, 2009, 04:57
Default swirling flow in simpleFoam compared with FLUENT
belinda is on a distinguished road
Hi all, good morning.
I am using simplefoam(v1.4) to calculate a swirling flow in chamber, the case is download from ERCOFTAC database.
http://cfd.mace.manchester.ac.uk/cgi...html&1&0&0&0&0
It is a 2D case.
But I got some problem.
When I want to compare the results with FLUENT ones, it seems that the result from FOAM have a great "dissipation".
i post the velocity magnitude here, you may find that the high velocity in FLUENT last long.
http://picasaweb.google.com/lh/photo...eat=directlink
I used realizable k epsilon model for both of them.
The grids are the same, y plus are around 60. (before this case, I run a case which y plus are around 5, the same thing happened.)
Both of them use the same velocity inlet.
the numerical schemes i used default ones, cause i confused by the differences between FOAM and FLUENT.
Please, give me your ideas.
Thanks.
belinda is offline   Reply With Quote
Viscoelastic flow modeling in Fluent Ankur Navra FLUENT 3 July 26, 2013 06:56
Oscillatory Flow in FLUENT phy FLUENT 0 February 2, 2008 11:19
how to deal with annular flow in fluent yong FLUENT 1 January 4, 2008 08:35
NUMERICAL INSTABILITY FOR FLOW OV. SWIRLING VANES D FLUENT 3 February 9, 2005 16:35
Is Fluent v4.5 efficient for transonic flow Pef FLUENT 0 March 8, 2002 11:43
