Error for multiphaseInterFOAM (RASModel)
Old   October 20, 2009, 07:15
Default Error for multiphaseInterFOAM (RASModel)
OF_User is on a distinguished road
Dear OF_Users!
Has anyone setup the dambrake4phase tutorial as RAS (kepsilon) instead of Laminar? I tried but failed.
I did follow actions:
- Change in turbulanceProperties to RASModel
- Created a RASProperties-file with kepsilon
- Introduced BC for k, epsilon and nut
I get following messages:
Create time
Create mesh for time = 0
Reading g
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type RASModel
Selecting RAS turbulence model kEpsilon
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/leorrc/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/leorrc/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 __restore_rt at sigaction.c:0
#3 Foam::incompressible::RASModels::nutWallFunctionFv PatchScalarField::calcNut() const in
"/home/leorrc/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libincompressibleRASModels.so"
#4 Foam::incompressible::RASModels::nutWallFunctionFv PatchScalarField::updateCoeffs() in
#5 Foam::fvPatchField<double>::evaluate(Foam::Pstream ::commsTypes) in
"/home/leorrc/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/multiphaseInterFoam"
#6 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::evaluate() in
#7 Foam::incompressible::RASModels::kEpsilon::kEpsilo n(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField,
Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&)
in "/home/leorrc/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libincompressibleRASModels.so"
#8 Foam::incompressible::RASModel::adddictionaryConst ructorToTable<Foam::incompressible::RASModels::kEp silon>
::New(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double,
Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&) in
#9 Foam::incompressible::RASModel::New(Foam::Geometri cField<Foam::Vector<double>, Foam::fvPatchField,
Foam::transportModel&) in "/home/leorrc/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libincompressibleRASModels.so"
#10 Foam::incompressible::turbulenceModel::addturbulen ceModelConstructorToTable<Foam::incompressible::RA SModel>
::NewturbulenceModel(Foam::GeometricField<Foam::Ve ctor<double>, Foam::fvPatchField, Foam::volMesh> const&,
Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&) in
#11 Foam::incompressible::turbulenceModel::New(Foam::G eometricField<Foam::Vector<double>, Foam::fvPatchField,
Foam::transportModel&) in "/home/leorrc/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libincompressibleTurbulenceModel.so"
#12 main in "/home/leorrc/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/multiphaseInterFoam"
#13 __libc_start_main in "/lib64/libc.so.6"
#14 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116
Floating point exception
Could you please advise what to do?
Thanks,
Mike
OF_User is offline   Reply With Quote
Old   October 20, 2009, 07:57
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
I am willing to bet quite alot that the initial value of epsilon (and/or bc) is zero.
niklas is offline   Reply With Quote
Old   October 20, 2009, 08:20
Hello Niklas!
I read this possible failure in an other threat. Therefore I checked k and epsilon with paraview and they are definitely not zero.
nice greetings
Mike
Old   October 20, 2009, 08:35
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
Hello OF_User,
Paraview is usually printing node values. What I think Niklas meant by check your k/epsilon values is to look inside the boundary condition dictionaries and see if the values are different from zero.
Dragos
dmoroian is offline   Reply With Quote
Old   October 20, 2009, 10:01
Hi Dragos!
Sorry, if i was not so clear in my statement. I checked the bc-files and did a cross check in paraview, if all the parameters are ok. But I found no mistake.
Mike
Old   October 20, 2009, 10:33
dmoroian's Avatar
Dragos
Hello Mike,
Could you post the k/epsilon dictionaries?
Dragos
Old   October 20, 2009, 10:51
Hello Dragos!
Here are my k/epsilon dictionaries.
Thanks for your help
Mike
k:
FoamFile
version 2.0;
format ascii;
class volScalarField;
location "0";
object k;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0.01;
boundaryField
leftWall
type kqRWallFunction;
value uniform 0.01;
rightWall
value uniform 0.01;
lowerWall
value uniform 0.01;
atmosphere
type inletOutlet;
inletValue uniform 0.1;
value uniform 0.1;
defaultFaces
type empty;
epsilon:
FoamFile
version 2.0;
format ascii;
location "0";
object epsilon;
dimensions [0 2 -3 0 0 0 0];
boundaryField
leftWall
type epsilonWallFunction;
value uniform 0.01;
rightWall
value uniform 0.01;
lowerWall
value uniform 0.01;
atmosphere
type inletOutlet;
value uniform 0.1;
defaultFaces
type empty;
Old   October 20, 2009, 11:15
dmoroian's Avatar
Dragos
Hello Mike,
Indeed you were right, and there are no zero values set, but at least the epsilon values look peculiar. An estimation of both k and epsilon is presented in the documentation http://www.opencfd.co.uk/openfoam/do...tml#x5-40002.1 (eq. 2.8 and 2.9) as well as in any CFD book.
Another thing that cought my attention was the "empty" condition, which means that you have a 3D domain with only one cell thickness. Is this true?
Dragos
Old   October 20, 2009, 11:23
Yes, Dragos, you are right, I use a 2D-case.
The starting conditions for k and epsilon are difficult. Theoretically in this case they should be 0, because at the beginning, there is no movement. But since I read about the problems, if they are 0, I used the mentioned values.
Mike
Old   October 20, 2009, 11:55
dmoroian's Avatar
Dragos
Hmm, and it does that from the first iteration.
Well, the only suggestion I have is to follow equation 2.9 in the documentation and specify a value of
0.09^0.75*k^1.5/l
for epsilon. Where
l = 0.07*characteristic_geometrical_length
...sometimes it helps
Dragos
Old   October 20, 2009, 21:04
J. Cai
chiven is on a distinguished road
I also have ever tried to run it in RAS model, and met the same problem.
Best regards,
Jiejin Cai
chiven is offline   Reply With Quote
Hybrid RANS LES braennstroem OpenFOAM Running, Solving & CFD 7 April 19, 2009 10:59
How to change the turbulance model sivakumar OpenFOAM Pre-Processing 9 February 17, 2009 06:56
Solve Simple foam for laminar flow nandiganavishal OpenFOAM Running, Solving & CFD 4 January 20, 2009 01:56
Add new RASModel kEpsilon modification ivanwhlau OpenFOAM Running, Solving & CFD 3 August 21, 2008 05:36
