Incompatibility between 2 boundary conditions in Pitzdaily case |
October 5, 2009, 12:23 |
Rep Power: 17 |
Hi all,
I've just noticed something weird in the 0-directory for the velocity U: We have: inlet { type turbulentInlet; referenceField uniform (10 0 0); fluctuationScale (0.02 0.01 0.01); value uniform (10 0 0); } outlet { type inletOulet; inletValue (0 0 0); // I thought it was (10 0 0) no ? value (0 0 0); } Indeed, I can't understand this latter, although the inlet velocity is defined by (10 0 0), we use a different one for the outlet BC. Does anybody know the reason ? Moreover I don't know why we have to specify the keyword ''value'' ? besides, in some cases it doesn't appear. Thank you in advance! |
October 5, 2009, 13:43 |
The inletValue in the inletOutlet boundary condition specifies the inflow velocity at your outlet - normally you want it to be zero to prevent inflow. Regards, Jose Santos |
October 6, 2009, 07:39 |
Rep Power: 17 |
Thank you for answering so quickly,
nevertheless, I've seen the documentation for "turbulentInlet" and it doesn't specify anything about the keyword "value", so what is the purpose of it ? Same question concerning "inletOutlet", because there is no change when we delete it. regards, Rom. |
October 9, 2009, 23:50 |
Huang
Rep Power: 17 |
By looking at the U file at other time, I think, value specifies the velocity at ascribed path. so, at time 0, the inelt velocity is uniformly 10, but it varies for other time.
October 20, 2009, 08:16 |
Rep Power: 17 |
yes, I think so as well.
thank you. |
Change in boundary conditions before rerun | achuneka | OpenFOAM Running, Solving & CFD | 5 | April 14, 2020 13:46 |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 15:53 |
symmetry boundary conditions in cfx | lost.identity | CFX | 41 | May 22, 2013 08:21 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 13:24 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 05:15 |
