yPlusRAS in OF 1.6.x - Low Re Models
Old   September 23, 2009, 06:27
Default yPlusRAS in OF 1.6.x - Low Re Models
Ivan Flaminio Cozza
ivan_cozza is on a distinguished road
Send a message via MSN to ivan_cozza
Hi Foamers,
I've just noticed that in OF 1.6.x you can only use yPlusRAS if you have a wallFunction on nut field. I'm trying to apply a low Re calculation with simpleFoam, SST model, so I've changed thewall bc on k to fixedValue and on nut to calculated, but in this cases yPlusRAS does not work. I've circumvented the problem adding a false wallfunction on nut just when calculating yPlusRAS, but is not so a clear approach. Has someone coded a yPlusRAS also for LowRE models?
Best regards,
Ivan
ivan_cozza is offline   Reply With Quote
Implementing low Re number k-e models in Fluent. kiran FLUENT 1 July 3, 2017 18:04
low reynolds number models in Fluent doug Main CFD Forum 6 August 4, 2012 15:39
low Re number k-epslon models Hossam FLUENT 1 July 13, 2008 06:00
Turbulence Models for very low Reynolds Numbers Sudhi CFX 1 March 2, 2007 19:03
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
