September 20, 2009, 20:11 |
Use of k omega turbulence model
John Weaver
Rep Power: 17 |
Hi folks,
Just wondering if anyone has encountered any difficulties using the k omega turbulence model within OF 1.6? I have been running a few simple simulations with the incompressible PisoFOAM solver that work very well with the k epsilon and k omega SST turbulence models. However, my solution diverges after a few time steps when I use the k omega turbulence model, even when I use exactly the same initial values (including k and omega) as with the k omega SST turbulence model. The simulation is simply an internal flow through a duct. Thanks, John |
September 21, 2009, 10:29 |
Paulo Alexandre Costa Rocha
Rep Power: 17 |
If you are running a transient simulation, try decreasing the time step. If it is steady state, decrease the relaxation factor. Which formula are you using to calculate omega at the boundaries? Best Regards, Paulo Rocha |
September 22, 2009, 06:15 |
Daniel WEI (老魏)
Rep Power: 21 |
My advise is to check CFL condition, fvSolutions, fvSchemes, and esp. the boundary conditions.
~ Daniel WEI ------------- Boeing Research & Technology - China Beijing, China |
k omega, k omega sst, turbulence model |
Adding a Turbulence Model | doug | OpenFOAM Running, Solving & CFD | 11 | May 21, 2018 14:54 |
SimpleFoam case with SpalartAllmaras turbulence model implemented | nedved | OpenFOAM Running, Solving & CFD | 2 | November 30, 2014 23:43 |
Eul-Eul flow, k-e-kp-ep-Theta Turbulence model | us | FLUENT | 5 | April 5, 2011 03:29 |
KOmega Turbulence model from wwwopenFOAMWikinet | philippose | OpenFOAM Running, Solving & CFD | 30 | August 4, 2010 11:26 |
v2-f turbulence model in CFX? | flga | CFX | 14 | November 23, 2006 07:12 |
