create cyclic patch
Old   September 17, 2009, 07:30
Default create cyclic patch
Andrea Pasquali
andrea.pasquali is on a distinguished road
I'm trying to use createPatch to create a patch type cyclic coupling two patches (type patch).
When I run createPacth I obtain:
#0 Foam::error:: printStack(Foam::Ostream&) in "/home/openfoam15x/OpenFOAM/OpenFOAM-1.5.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigSegv::sigSegvHandler(int) in "/home/openfoam15x/OpenFOAM/OpenFOAM-1.5.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 __restore_rt at sigaction.c:0
#3 Foam::face::normal(Foam::Field<Foam::Vector<double > > const&) const in "/home/openfoam15x/OpenFOAM/OpenFOAM-1.5.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#4 Foam::cyclicPolyPatch::getCentresAndAnchors(Foam:: PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&, Foam::List<Foam::face> const&, Foam::List<Foam::face> const&, Foam::Field<Foam::Vector<double> >&, Foam::Field<Foam::Vector<double> >&, Foam::Field<Foam::Vector<double> >&, Foam::Field<double>&) const in "/home/openfoam15x/OpenFOAM/OpenFOAM-1.5.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#5 Foam::cyclicPolyPatch:: order(Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&, Foam::List<int>&, Foam::List<int>&) const in "/home/openfoam15x/OpenFOAM/OpenFOAM-1.5.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#6 Foam: polyTopoChange::reorderCoupledFaces(bool, Foam: polyBoundaryMesh const&, Foam::List<int> const&, Foam::List<int> const&, Foam::Field<Foam::Vector<double> > const&) in "/home/openfoam15x/OpenFOAM/OpenFOAM-1.5.x/lib/linux64GccDPOpt/libdynamicMesh.so"
#7 Foam: polyTopoChange::compactAndReorder(Foam: polyMesh const&, bool, bool, bool, int&, Foam::Field<Foam::Vector<double> >&, Foam::List<int>&, Foam::List<int>&, Foam::List<Foam:: objectMap>&, Foam::List<Foam:: objectMap>&, Foam::List<Foam:: objectMap>&, Foam::List<Foam:: objectMap>&, Foam::List<Foam:: objectMap>&, Foam::List<Foam:: objectMap>&, Foam::List<Foam:: objectMap>&, Foam::List<Foam:: objectMap>&, Foam::List<Foam::Map<int> >&, Foam::List<int>&, Foam::List<int>&, Foam::List<Foam::Map<int> >&) in "/home/openfoam15x/OpenFOAM/OpenFOAM-1.5.x/lib/linux64GccDPOpt/libdynamicMesh.so"
#8 Foam:: polyTopoChange::changeMesh(Foam:: polyMesh&, bool, bool, bool, bool) in "/home/openfoam15x/OpenFOAM/OpenFOAM-1.5.x/lib/linux64GccDPOpt/libdynamicMesh.so"
#9 main in "/home/openfoam15x/OpenFOAM/OpenFOAM-1.5.x/applications/bin/linux64GccDPOpt/createPatch"
#10 __libc_start_main in "/lib64/libc.so.6"
#11 __gxx_personality_v0 in "/home/openfoam15x/OpenFOAM/OpenFOAM-1.5.x/applications/bin/linux64GccDPOpt/createPatch"
Segmentation fault
This is my createPacth dictionary:
matchTolerance 1e-6;
pointSync true;
patches
name FAN_SERVER_1;
type cyclic;
constructFrom patches;
patches (SERVER_1_INLET SERVER_1_OUTLET);
name FAN_SERVER_2;
type cyclic;
patches (SERVER_2_INLET SERVER_2_OUTLET);
name FAN_PORTA;
type cyclic;
patches (PORTA_LATO_CANTINA PORTA_LATO_CORRIDOIO);
Does anyone knowns where is the matter?
Regards,
Andrea
andrea.pasquali is offline   Reply With Quote
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 02:07
CheckMeshbs errors ivanyao OpenFOAM Running, Solving & CFD 2 March 11, 2009 03:34
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
