conjugateHeatFoam: Should solid and fluid have the same mesh at the coupled boundary?
Old   September 15, 2009, 23:12
Default conjugateHeatFoam: Should solid and fluid have the same mesh at the coupled boundary?
Jitao Liu
awacs is on a distinguished road
Hi all,
Should the solid region and fluid region have the same mesh grid at the coupled boundary when using the conjugateHeatFoam solver?
Will it work if I define the coupled boundary for solid and fluid as following:
For solid:
cavityTop
type regionCouple;
nFaces 50;
startFace 8890;
shadowRegion region0;
shadowPatch polymerMeltTop;
attached on;
For fluid:
polymerMeltTop
type regionCouple;
nFaces 100;
startFace 3920;
shadowRegion solid;
shadowPatch cavityTop;
attached on;
Thanks in advance.
Regards,
Jitao
awacs is offline   Reply With Quote
Old   September 16, 2009, 08:08
Petri Sulasalmi
PetSul is on a distinguished road
is conjugateHeatFOAM same as chtMultiRegionFoam?
Regards,
Petri
PetSul is offline   Reply With Quote
Old   September 16, 2009, 14:42
akidess's Avatar
Anton Kidess
Originally Posted by PetSul View Post
Regards,
Petri
No. chtMRF does coupling by copying values at the domain boundary, while conjugateHF assembles a large matrix for all domains and solves it as one.
Old   September 17, 2009, 02:14
Petri Sulasalmi
I have a simple case with hot fluid region, with zero fluid velocity, and cold solid region. I'd like simulate heat transfer between the regions. Which one of these solvers would you recommend?
Regards,
Petri
Old   September 17, 2009, 06:19
su_junwei's Avatar
su junwei
su_junwei is on a distinguished road
Send a message via MSN to su_junwei
Hi Jitao
It seems they did an interpolation at the coupled interface, so you don't have to set the same mesh.
Junwei
su_junwei is offline   Reply With Quote
Old   September 17, 2009, 15:13
akidess's Avatar
Anton Kidess
Regards,
Petri
chtMRF should work just fine and is part of the standard OpenFOAM package.
Old   September 22, 2009, 23:58
Jitao Liu
Originally Posted by su_junwei View Post
Hi Jitao
Junwei
Hi Junwei,
Thanks for your kind reply to my post above. I will try it out.
Best wishes,
Jitao
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
increasing mesh quality is leading to poor convergence tippo CFX 2 May 5, 2009 11:55
No results for solid domain Gary Holland CFX 10 March 13, 2009 04:30
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 7, 2008 00:17
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
