September 14, 2009, 04:06 |
decompose with wallfunctions
Niels Nielsen
Rep Power: 27 |
Hi
I'm having some problems decomposing a case with wallfunctions. If I run it in serial there are no problems but when trying to decompose I get this error (below). If I add the "value uniform 0;" below the kqRWallFunction line I can decompose but I don't see why this should be required when using high Re turb model in parallel. My k and epsilon entry for the wall propeller { type kqRWallFunction; } propeller { type epsilonWallFunction; }
From function genericFvPatchField<Type>::genericFvPatchField(con st fvPatch&, const Field<Type>&, const dictionary&) |
September 14, 2009, 10:23 |
santhosh
Rep Power: 17 |
I also faced this problem. One trickier solution would be to run in serial till the openFOAM creates new k and epsilon files and moves old files as k.old and epsilon.old, try decomposepar then.
But It would be nice if decomposePar utility changed to consider keqWallfunction boundary too. Santosh.. |
September 14, 2009, 11:22 |
Niels Nielsen
Rep Power: 27 |
I did something similar.
I just decomposed and then deleted the "value" line in each of the k/epsilon files under each processor folder, not a nice approach but it works :-) |
October 16, 2009, 05:03 |
John Wang
Rep Power: 17 |
Humm... I've read some post that uses
value $internalField; not sure what it does, but seems to be working. |
October 16, 2009, 06:41 |
Matteo Carpentieri
Rep Power: 17 |
as far as I understand the behaviour of the wall function routines in OpenFOAM, I believe that the values in the BC are just placeholders. They are not used by the solvers and are re-calculated for the wall patches. However, some of the utilities will complain if a value is not provided (decomposePar and paraFoam, for example). I believe this is a bug, and the only solution, for now, is to provide 'dummy' values (for example the same value as the internal field, or 0). This is just my opinion, maybe someone more expert than me will deliver a better answer @cwang5: I think that statement is just another way of using the internal field values; as I was saying above, it should not have any effect on the calculations. |
[CGNS] CGNS converters available | mbeaudoin | OpenFOAM Meshing & Mesh Conversion | 137 | December 14, 2018 04:20 |
Wallfunctions onoff | gjesing | OpenFOAM Running, Solving & CFD | 5 | February 10, 2010 23:55 |
Regarding wallFunctions | Hectux | OpenFOAM Running, Solving & CFD | 0 | May 29, 2009 03:23 |
Serial OK parallel failsmesh conversion problem | r2d2 | OpenFOAM Running, Solving & CFD | 15 | July 31, 2008 15:04 |
Bug in twoPhaseEulerFoam wallfunctions | alberto | OpenFOAM Bugs | 1 | February 9, 2007 14:15 |
