September 10, 2009, 18:15 |
dieselfoam LISA spray model
Jerry Lee
Rep Power: 17 |
Has anyone tried to run dieselFoam with LISA as the atomization model.
I have a following questions. 1 - do I leave the injectormodel on (say set to unitinjector)? 2 - set atomizationmodel to LISA what are the model parameters: (CL cTau, Q, J)? Are these all the parameters I need for LISA along with the RosinRammer parameters for the droplet size distribution? Q = gas density/liquid density cTau = breakup time (but shouldn't this be an output of the LISA model?) J is a constant in Senecal's paper but what value should it be set to? CL=? |
September 11, 2009, 03:58 |
Christof Benz
Rep Power: 17 |
Hi Jerry,
i didnt work with LISA until yet. The constants for the models are described in detail at the following papers: P.K. Senecal, D.P. Shmidt, I. Nouar, C.J. Rutland, R.D. Reitz, M. Corradini "Modeling high-speed viscous liquid sheet atomization" International Journal of Multiphase Flow 25 (1999) pags. 1073-1097 D.P. Schmidt, I. Nouar, P.K. Senecal, C.J. Rutland, J.K. Martin, R.D. Reitz "Pressure-Swirl Atomization in the Near Field" SAE Techical Paper Series 1999-01-0496 Christof |
September 11, 2009, 10:22 |
some input are not used... I think.
Jerry Lee
Rep Power: 17 |
Thank you very much Christof for your response.
Q and J are strange. Q clearly is the gas to liquid density ratio and I don't know what J is. The strange thing is that it seems (from reading the source code) that the input values of both Q and J are ignored and they are calculated in the code. cTau is the perturbation ratio at the onset of breakup. The nomenclature found in both of the papers you quoted are not followed in the code. By comparing the experssions, I figured out (with helps from one of the original author of LISA) some of them. Does anyone know a tutorial using LISA out there somewhere? Thank you very much. |
September 25, 2009, 21:57 |
Lisa
HuangWei
Rep Power: 17 |
as i know,in LISA J=0,but i don't know what's that mean. |
March 18, 2010, 06:41 |
Rep Power: 17 |
Ive been looking into this for a while, but cant find the complete analogy between the code and the articles.
Q = gas/liquid density ratio c_Tau = breakup time C_L=characteristic breakup length? J = constant as in Senecal et al. Did anyone figure out exactly what they are and what they should be set to? |
June 14, 2010, 12:48 |
Where does lisaExp come from?
Lakshman
Rep Power: 17 |
Hello all,
I have recently started looking into the LISA implementation. I started by comparing between the paper and the code. In the LISA code, I see a variable called lisaExp (set to 0.27). I am not sure where this comes from because it is not present in the reference paper. Also, I can not understand the physics behind using "pRatio=spray_.ambientPressure()/ambientPressure;" Why does this affect the droplet diameter? It would be great if anybody could throw some light on this. Thanks, Suraj |
August 11, 2011, 10:27 |
#7 | |
chenkai
Rep Power: 16 |
Hallo Suraj, I have the same problem like you said. Have you solve this problem? Could you please tell me what means here: "pRatio=spray_.ambientPressure()/ambientPressure;" und what is the function of lisaExp (set to 0.27). Thanks a lot in advance! Chenkai |
January 20, 2014, 10:25 |
LISA atomization model test case
Nisha
Rep Power: 17 |
I am looking for a test case with implementation of LISA atomization model.
I've tried looking at the tutorials, but I could not find proper sprayCloudProperties file with the constants needed for the model. Can anybody help please ? Thank you. |
May 16, 2014, 11:48 |
#9 | |
Have you found any tutorial for LISA model or any idea on how to set up the 'sprayCloudProperties' for LISA model? Can you share some information? Thank you. |
LISA model | brajh11 | CFX | 0 | May 15, 2009 11:49 |
the role of the atomization model | Jay | Siemens | 2 | March 7, 2008 21:16 |
How to model spray condensor in 3-D? | summer | FLUENT | 0 | April 25, 2006 12:30 |
DPM model w/ Wave model - errors in documentation | HS | FLUENT | 0 | April 12, 2006 05:37 |
Reference/s for Spray model | Abhijeet Vaidya | Main CFD Forum | 2 | October 29, 2001 08:15 |
