how to use openfoam for supersonic reacting flows?
Old   September 10, 2009, 04:34
Post how to use openfoam for supersonic reacting flows?
MSR CHANDRA MURTHY
chandramurthy is on a distinguished road
Hi Fomers,
i am a PhD student, doing research in supersonic reacting flows confined in diverging ducts. i have been trying to understand the OpenFoam software for implementing it for the Scramjet like applications. The flow field is in the upper bounds of supersonic regime (Mach 3). Energy-flow coupling cannot be neglected.
i have few questions regarding openfoam capabilities.
1) does the software have pure density based solver using Roe/AUSM+ scheme?
2) Does it have the EDC model for combustion modeling with Gran's EDC Correction for finite rate chemical kinetics?
3) what can be the numerical solution strategy for scramjet like applications in OpenFoam?
can any body help to get more insight into openfoam!
chandramurthy is offline   Reply With Quote
Old   November 19, 2018, 21:57
linzihan
Lynn009 is on a distinguished road
Hi, I am a student of doing some simulation in OpenFOAM. Have you solved the problem of supersonic combustion? If you have solved that, could you mind sending me your case and solver? Thank you very much ~
Lynn009 is offline   Reply With Quote
Old   November 20, 2018, 09:20
Vince
hyFoam is on a distinguished road
Please check this post: Hypersonic and Supersonic Flow Solvers
and the hyFoam solver on Github: https://github.com/vincentcasseau/hyStrath
Thanks
hyFoam is offline   Reply With Quote
Old   November 20, 2018, 22:42
linzihan
Hi, I have downloaded the hy2Foam. I copy the applications/compressible and src into OpenFOAM, but it can't find some documents and I can't find that in your folders.
like: hy2Foam_include.H:15:33: fatal error: relaxationTimeModel.H:compilation terminated.
Did I do something wrong? Thank you a lot.
Old   November 21, 2018, 04:22
Vince
Did you follow the installation steps in the Github Wiki? There's nothing to copy manually, only a script to be run.
Thanks.
Old   November 22, 2018, 09:11
linzihan
I can't enter the outlook web app. Is that something wrong?
I have installed OpenFOAM1706, and downloaded the hyStrach-master. But I can't do right with the installation of readme . It reminds me : fatal:the index-pack failed.
Can you tell me something? Thank you very much!
Old   November 22, 2018, 09:19
linzihan
Hi
Could I have your E-mail? I will write more details what I do wrong with pictures.
Old   November 22, 2018, 09:38
Vince
The contact email can be found here:
https://github.com/vincentcasseau/hy...ontact#contact
Thanks.
Old   December 11, 2018, 02:49
linzihan
hi,
I have installed OF-v1706, and according to your links to install:https://github.com/vincentcasseau/hy...#master-branch
But when I install the CFD,DSMC and hybrid PIC-DSMC, uses the codes:./install-all.sh 8 > logInstall 2>&1 &
it appears mkdir: Missing operand
Please tell me how to do right.
Old   December 11, 2018, 05:28
Vince
Hi Lynn,
Getting Started: mkdir missing operand
Does it help?
Thanks,
Vincent
combustion, edc, scramjet
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 06:56
Multiphase and FreeSurface Flows at OpenFOAM Workshop Milan 2008 egp OpenFOAM 0 March 20, 2008 07:34
Reacting Flows using PDF Methods Gede Main CFD Forum 6 November 29, 2005 22:13
can u suggest me a paper to benchmark the code for quasi-1d reacting flows RAMIREDDY.V.MUVVA Main CFD Forum 0 April 25, 2000 05:51
