Temperature Dependent Fluid Properties
Old   September 8, 2009, 01:16
Default Temperature Dependent Fluid Properties
eliwide is on a distinguished road
I am trying to run a model with buoyantSimpleFoam with temperature dependent material properties but as a newbie I do not know where to start when editing the thermophysicalProperties file. I have the model running without any issues with constant properties but I need to model them as temperature dependent.
It seems that it is possible, since Chapter 7.1 of the user guide says that Cp can be defined by a polynomial using "hPolynomialThermo" and the thermodynamic transport properties with "polynomialTransport".
If someone could provide an example, that would be a huge start.
Thanks for the help
eliwide is offline   Reply With Quote
Old   September 8, 2009, 22:09
J. Cai
chiven is on a distinguished road
Hi, dear eliwide, you can reference to the buoyantBoussinesqSimpleFoam solver, which the rho is dependent on the temperature.
best regards,
Chiven
chiven is offline   Reply With Quote
Old   September 9, 2009, 07:42
Default tempreture-dependent density for incompresible LES
mmahdinia is on a distinguished road
I am using incompressible LES solver for flow over step simulation. I have added the turbulent heat equation to the solver but still I don't know how to implement a temperature dependence for the density.
Can anyone tell me how to employ a density with a linear dependence on temperature (without using the OpenFOAM compressible codes)?
mmahdinia is offline   Reply With Quote
Old   March 23, 2011, 16:41
Maryam Mousazadeh
anijdon is on a distinguished road
hello;
I want to simulate an incompressible nanofluid flow with heat transfer using simpleFoam (i.e. solver includes an energy equation). The conductivity and viscosity of the fluid is temperature dependent . I don't know haw can modify the solver and case directories to these properties become temperature dependent ;you had similar problem, if you was succeeded in resolving would you help me?
thanks
kind regards
anijdon is offline   Reply With Quote
Old   December 15, 2012, 20:21
sorush ahmadian
sahmadian is on a distinguished road
I am new in using OpenFOAM. The problem I am looking at is a freezing process of foods. So it is a solidification problem with temperature dependent properties. Any information in regard to the temperature dependent properties?
sahmadian is offline   Reply With Quote
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 08:59
How to define Fluid properties as a Function of T Md Hamidur CFX 2 September 12, 2007 16:05
Fluid properties fea user CFX 3 May 9, 2006 10:12
to take K & Cp as temperature dependent kishore rathore FLUENT 1 February 17, 2004 05:33
UDF Scalar Code: HT 1 Greg Perkins FLUENT 8 October 20, 2000 13:40
