Segmentation fault
Old   September 7, 2009, 06:11
Default Segmentation fault
andrianah scott
adrianahscott is on a distinguished road
Hi there,
Can somebody out there tell me what ''Segmentation fault"means?
I'm dealing with squeezing mesh and the displacement of each cell is calculated(volscalarfield) and when I display the result with parafoam it comes out with this error message!!
Best Regards
Thanks in advance!!
adrianahscott is offline   Reply With Quote
Old   September 7, 2009, 08:25
Anonymous
madad2005 is on a distinguished road
A segmentation fault is generally associated with a memory error. You may have run out of memory, or you may be trying to access a location in memory that doesn't contain what you need. I normally get them when I mix up my 32-bit and 64-bit executables when reading in large data sets.
madad2005 is offline   Reply With Quote
Old   September 7, 2009, 10:17
andrianah scott
Thank you so much for answering me,nice of you.I'm actually trying to handle an automatic mesh motion(squeezing mesh) and I came out with this error.
Did you happen to deal with it?I don't have much experience.
The displacement of each cell is calculated(pointscalarfield)and loaded into the pointdisplacement file.Woul be so kind as to give me a hand?I can't get at it!totally stuck!
BR
Thank you in advance!
Segmentation fault when running dieselFoam or dieselEngineFoam in parallel francesco OpenFOAM Bugs 4 May 2, 2017 22:59
Debugging a segmentation fault? hansel OpenFOAM Bugs 3 July 31, 2010 14:13
Segmentation fault. Nari Siemens 3 November 8, 2007 06:04
segmentation fault usker Siemens 5 March 6, 2007 00:14
KIVA and Segmentation Fault Felix Main CFD Forum 2 January 18, 2006 02:24
