Pass a variable from a class to a subequation in the main solver
Old   September 3, 2009, 13:03
Default Pass a variable from a class to a subequation in the main solver
lord_kossity's Avatar
Andreas Dietz
lord_kossity is on a distinguished road
Hi all!
I'm trying to combine two solvers, namely a VoF solver and a particle tracking solver.
The VoF solver evolved from rasInterFoam, the particle tracking solver from dieselFoam. At the moment I'm stuck at the point where the transfer from lagrangian to eulerian point of view takes place.
The application is a drop impinging on a solid surface. I am able to print out where the deletion of the particle occurs and to manually insert a source term to the VoF-method. Of course this should be automated. Therefore I need to transfer the value "depositionCell" from the wall model in the dieselSpray class to the alphaEqn in the interFoam solver. How is that feasible?
Best,
Andreas
lord_kossity is offline   Reply With Quote
Variable value with time - from SOLVER FILE Tuks CFX 4 July 11, 2005 06:49
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
CFX 5.5 Roued CFX 1 October 2, 2001 17:49
Setting a B.C using UserFortran in 4.3 tokai CFX 10 July 17, 2001 17:25
