Ho to model the flow in a Regenerator
Old   August 23, 2009, 18:30
Default Ho to model the flow in a Regenerator
Alexandre Pereira
alexandrepereira is on a distinguished road
Hi Forum
I am considering to use OpenFOAM to model a closed gas circuit comprising two heat exchangers and one regenerator.
The problem involves turbulent flow and conjugate heat exchange.
I can model the HEX part using chtMultiRegionFoam, but as for the regenerator section, I plan to model a fine dense metallic wire mesh, having a very large surface to volume ratio ( the reduced period and length of the regenerator are low ), and using chtMultiRegionFoam here would entail me to explicitly mesh this thing... this is a no-go.
That leaves me with rhoPorousSimpleFoam.
Does anyone here knows how to model anisotropic thermal conductivity in the wire mesh ( transversally very high, and longitudinally very low ) as well as the heat storage effect... within rhoPorousSimpleFoam...?
Simply patching one more equation and a scalar field for temperature in the mesh in rhoPorousSimpleFoam wont do, because the flow field and the heat convective transport are strongly coupled...
Is "hacking" rhoPorousSimpleFoam the most numerically "sane" way to model a dense packed bed or wire mesh regenerator... or are there any smarter choices...?
Thanks in advance
Alex
alexandrepereira is offline   Reply With Quote
Old   August 24, 2009, 14:30
Default Thermal storage
Alexandre Pereira
C'mon ppl...
Is there nobody interested in recovering thermal energy from a flow... :-) ?
Alex
Old   August 25, 2010, 18:35
Zdeth
zdeth is on a distinguished road
Alex,
Have you come across a solution to modeling the regenerator? I'm trying to model one myself and would really really like to find a way to do it with out explicitly meshing something like that. Please let me know
(I'm using ICEM and Fluent v12)
-Christopher
zdeth is offline   Reply With Quote
volume fractions in homogeneous flow model? Matthias Rohner CFX 1 August 26, 2007 19:42
Laminar flow in species transport model? Neha Rao FLUENT 7 February 25, 2006 03:23
Baldwin-Lomax model in wall jet flow K.S.Chang Main CFD Forum 0 December 7, 2005 02:51
Please help with flow around car modelling! Tudor Miron CFX 17 March 19, 2004 20:23
Supersonic flow over flat plate - best model Chris Rand FLUENT 4 October 3, 2000 07:58
