High U and P forming on borders
Old   August 19, 2009, 14:57
Default High U and P forming on borders
Steve Hansel
hansel is on a distinguished road
I'm trying to simulate VAWTs in 2d. My simulations will run for 1000's of iterations (100s of ms of simulated time) and eventually somewhere on the edge (not in a corner) the U and P starts to go crazy. It's like a black hole forms in my simulated universe, and there is no pressure or velocity track that would indicate the cause is in anyway the turbine being tested.
My boundary conditions are:
Inlet fixed uniform U
outlet fixed uniform pressure of 0
The turbine is moving wall velocity, fixed U of 0.
Top and bottom are empty
I used zeroGradient for every other factor not mentioned, for U, P, epsilon, and k.
Do my boundary conditions provide too much freedom? I'm using turbDyMFoam but the problem happens in icoDyMFoam also and I believe simple icofoam.
Can anyone suggest better boundary conditions for a simulated 2d wind tunnel with an object in it? Should I have used slip or uniform U on the sides?
I realize I haven't posted all the properties, cooefficients, etc. If they are needed, please ask and I will post them.
hansel is offline   Reply With Quote
Old   August 30, 2009, 19:02
Steve Hansel
I didn't get much help here, but through trial and error found that non-slip walls in a sufficiently large wind tunnel gave the best results. You can expect a high pressure cell in the corner, where the fixed velocity side meets the no velocity side. I was a little surprised that didn't blow up, but it seems to be tolerated by the solvers.
Old   August 30, 2009, 23:28
J. Cai
chiven is on a distinguished road
Hi, dear Hansel, for outflows with zeroGradient for U don't use zeroGradient for transported quantities like k, epsilon and T. Please use inletOutlet. Otherwise things might explode when you get a backflow there.
best regards,
Chiven
chiven is offline   Reply With Quote
Old   August 31, 2009, 01:46
Steve Hansel
best regards,
Chiven
Thanks for the pointer, that was probably my original problem. My sides were zeroGradient for U and everything else.
2d wind tunnel, boundary conditions
flow with high turbulent viscosity ratio Phillips Main CFD Forum 2 August 25, 2008 19:01
flow with high turbulent viscosity ratio Phillips FLUENT 0 August 24, 2008 19:01
High Aspect Ratio elements Flavio CFX 2 November 24, 2006 13:01
Interface between meshes and high skewness Danny FLUENT 0 September 13, 2005 12:23
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
