Surface-mounted cube in turbulent regime using k-epsilon |
August 14, 2009, 07:49 |
Daniel Harlacher
Rep Power: 17 |
I am using a 3D Mesh created in Gambit and I am trying to visualize the flow past a cube at Re=20.000. I have the mesh running for a couple of days now and my problem is, that the side force coefficients (which are computed by OF using the appropriate libs) are decreasing (see attachment), so that I am afraid of getting a stationary result in the end. What could be the reson for that ? Here my config. and some pictures: I am using turbFoam with a DeltaT of 0.0078 which results in a theoretical Co. No. of about 0.75. I use a velocity inlet with U = 1 m/s (resulting in a viscosity of 0.00005) I use a pressure outlet with p = 0 So far I've been using Euler as time and upwind as convective discretization scheme. I wanted to wait until I have a constatn amplitude for the side forces before switching to higher order schemes. The lower wall is a wall and the upper boundary is set to symmetry right now. My grid has the dimensions 42h x 24h x 12.5h where h is the cubes height. I will assist with all my resources if asked for - I just didn't want to overload the post. Thanks in advance. I had a similar Problem with a sphere in a similar setup and it also tended to become stationary despite the high reynolds numbers - maybe there is a general bug in my setup ? BTW: When I am using the same BCs and calcualte a 2D cylinder everything works fine - so it works on some level ... Last edited by harly; August 14, 2009 at 07:51. Reason: Forgot to mention |
Bubblze induced turbulence at a free surface ???? | thomas | Main CFD Forum | 6 | April 21, 2012 10:48 |
Flame Surface Density. | Burn Ing | Main CFD Forum | 3 | December 5, 2004 18:12 |
Channel with 2D surface mounted obstacle | Francesco Marra | Main CFD Forum | 1 | January 5, 2000 04:49 |
Flow past circular cylinder(s) in turbulent regime | N. Jalaiah | Main CFD Forum | 9 | October 8, 1999 11:39 |
Turbulent Dissipation Rates - epsilon | Otute | Main CFD Forum | 5 | May 20, 1999 11:51 |
